Datasheet AD815 (Analog Devices) - 5
ОписаниеHigh Output Current Differential Driver
Страниц / Страница15 / 5 — AD815. TA = 25. VS =. 15V. 10V. V I N. 1/2. RTI OFFSET – mV. f = 0.1Hz …
ВерсияD
Формат / Размер файлаPDF / 527 Кб
AD815. TA = 25. VS =. 15V. 10V. V I N. 1/2. RTI OFFSET – mV. f = 0.1Hz 100. –10. –20. VOUT. 49.9. INPUT OFFSET VOLTAGE – mV. S =. RL =. –12. –40. –14. –60. 100
AD815 TA = 25 VS = 15V 10V V I N 1/2 RTI OFFSET – mV f = 0.1Hz 100 –10 –20 VOUT 49.9 INPUT OFFSET VOLTAGE – mV S = RL = –12 –40 –14 –60 100
27 предложений от 26 поставщиков
IC LINE DRIVER, PDSO24, THERMALLY ENHANCED, SOIC-24, Line Driver or Receiver
AD815ARB-241 483 ₽
AD815AYS+по запросу
МосЧип
AD815ARB-14по запросу
AD815ARB24по запросу
AD815 0 80 TA = 25
C –2 60 VS =
15V –4 40 VS =
5V VS =
10V –6 20 VS =
5V –8 0 V I N 1/2 RTI OFFSET – mV f = 0.1Hz 100
AD815 –10 –20 VOUT V 49.9
15V RL = –12 –40 5
1k
1k
–14 –60 –40 –20 0 20 40 60 80 100 –2.0 –1.6 –1.2 –0.8 –0.4 0 0.4 0.8 1.2 1.6 2.0 JUNCTION TEMPERATURE –
C LOAD CURRENT – Amps
Figure 10. Input Offset Voltage vs. Temperature Figure 13. Thermal Nonlinearity vs. Output Current Drive
750 VS =
15V
100 700 SOURCE 10 650 VS =
5V 600 1 VS =
15V SINK 550 0.1 SHORT CIRCUIT CURRENT – mA 500 CLOSED-LOOP OUTPUT RESISTANCE – 0.01 450 –60 –40 –20 0 20 40 60 80 100 120 140 30k 100k 300k 1M 3M 10M 30M 100M 300M JUNCTION TEMPERATURE –
C FREQUENCY – Hz
Figure 11. Short Circuit Current vs. Temperature Figure 14. Closed-Loop Output Resistance vs. Frequency
15 T V A = 25
C T S =
10V 40 A = 25
C V 10 S = ±15V RL = 25
VS =
5V VS =
15V RL = 100
5 30 0 RL = 50
20 V I N 1/2 RTI OFFSET – mV f = 0.1Hz –5 100
AD815 V R OUT L = 25
49.9
R 10 L = –10 25
1k
1k
DIFFERENTIAL OUTPUT VOLTAGE – V p-p RL = 1
–15 0 –20 –16 –12 –8 –4 0 4 8 12 16 20 0 2 4 6 8 10 12 14 FREQUENCY – MHz VOUT – Volts
Figure 12. Gain Nonlinearity vs. Output Voltage Figure 15. Large Signal Frequency Response REV. D –5– Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION MAXIMUM POWER DISSIPATION Typical Performance Characteristics THEORY OF OPERATION Choice of Feedback and Gain Resistors PRINTED CIRCUIT BOARD LAYOUT CONSIDERATIONS POWER SUPPLY BYPASSING DC ERRORS AND NOISE POWER CONSIDERATIONS Other Power Considerations Parallel Operation Differential Operation Creating Differential Signals Direct Single-Ended-to-Differential Conversion Twelve Channel Video Distribution Amplifier OUTLINE DIMENSIONS Ordering Guide Revision History
