Datasheet OP275 (Analog Devices) - 5
Описание | Bipolar/JFET, Audio Dual Op Amp |
Страниц / Страница | 12 / 5 — OP275–Typical Performance Characteristics. OP275. 100. AVCL = +1. … |
Версия | C |
Формат / Размер файла | PDF / 289 Кб |
Язык документа | английский |
OP275–Typical Performance Characteristics. OP275. 100. AVCL = +1. NEGATIVE EDGE. –VOM. POSITIVE EDGE. GBW. +VOM. OVERSHOOT – 30. VS =. 15V
OP275–Typical Performance Characteristics OP275 11 65 100 16 z 90 AVCL = +1 NEGATIVE EDGE 14 V 80
–VOM
10 60 12 Øm 70 % 10 60 AVCL = +1 9 55 50 POSITIVE EDGE 8 GBW 40 +VOM 6 OVERSHOOT – 30 VS =
15V 8 50 R 4 PHASE MARGIN – Degrees 20 L = 2k
T V A = 25
C MAXIMUM OUTPUT SWING – GAIN BANDWIDTH PRODUCT – MH IN = 100mV p-p V 10 2 S =
15V 7 40 0 0 –50 –25 0 25 50 75 100 0 100 200 300 400 500 100 1k 10k TEMPERATURE –
C LOAD CAPACITANCE – pF LOAD RESISTANCE –
TPC 10. Gain Bandwidth Product, TPC 11. Small Signal Overshoot vs. TPC 12. Maximum Output Phase Margin vs. Temperature Load Capacitance Voltage vs. Load Resistance
30 5.0 120 110 VS =
15V V 25 100 4.5 90 20 SINK TA = +85
C 80 15 4.0 TA = +25
C 70 TA = 25
C T 60 10 VS =
15V A = –40
C AVCL = +1 50 R 3.5 L = 2k
SUPPLY CURRENT – mA 5 40 MAXIMUM OUTPUT SWING – SOURCE ABSOLUTE OUTPUT CURRENT – mA 30 0 3.0 20 1k 10k 100k 1M 10M 0
5
10
15
20
25 –50 –25 0 25 50 75 100 FREQUENCY – Hz SUPPLY VOLTAGE – V TEMPERATURE –
C
TPC 13. Maximum Output TPC 14. Supply Current vs. TPC 15. Short-Circuit Current Swing vs. Frequency Supply Voltage vs. Temperature
300 5 500 V V =
15V S =
15V S VS =
15V T = 25 250 Hz
C A –40
C to +85
C 4 400 BASED ON 920 OP AMPS 200 3 300 150 2 UNITS 200 100 1 INPUT BIAS CURRENT – nA 100 50 CURRENT NOISE DENSITY – pA/ 0 0 –50 –25 0 25 50 75 100 10 100 1k 100k 0 1 2 3 4 5 6 7 8 9 10 TEMPERATURE –
C FREQUENCY – Hz TCVOS –
V/
C
TPC 16. Input Bias Current vs. TPC 17. Current Noise Density TPC 18. TCVOS Distribution Temperature vs. Frequency –4– REV. C REV. C –5– Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONNECTIONS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE Typical Performance Characteristics APPLICATIONS Circuit Protection Total Harmonic Distortion Noise Noise Testing Input Overcurrent Protection Output Voltage Phase Reversal Overload or Overdrive Recovery Measuring Settling Time Driving Capacitive Loads High Speed, Low Noise Differential Line Driver A 3-Pole, 40 kHz Low-Pass Filter OP275 SPICE Model OUTLINE DIMENSIONS Revision History
