Datasheet OP07 (Analog Devices) - 8
| Производитель | Analog Devices |
| Описание | Ultralow Offset Voltage Op Amp |
| Страниц / Страница | 16 / 8 — OP07. Data Sheet. 1000. VS = ±15V. RS1 = RS2 = 200kΩ THERMAL NOISE … |
| Версия | G |
| Формат / Размер файла | PDF / 231 Кб |
OP07. Data Sheet. 1000. VS = ±15V. RS1 = RS2 = 200kΩ THERMAL NOISE SOURCE. ) z. RESISTORS INCLUDED. / H. EXCLUDED. n (. nV (. 100. OP07C. CURRE
52 предложений от 26 поставщиков Усилители.Количество: каналов - 1Выходной ток: на канал - 15 мАВес брутто: 0.37Транспортная упаковка: размер/кол-во: 60*50*50/2000Напряжение питания: ± 3 (min)…± 18 (max)... |
| OP07CSZ-REEL
| 92 ₽ | |
| OP07CSZ-REEL7 Analog Devices | 148 ₽ | |
| OP07CSZ-REEL7 Analog Devices | по запросу | |
| OP07CSZ-REEL7
| по запросу | |
OP07 Data Sheet 4 1000 VS = ±15V RS1 = RS2 = 200kΩ THERMAL NOISE SOURCE ) z RESISTORS INCLUDED 3 A) / H EXCLUDED n ( nV ( 100 NT GE OP07C 2 CURRE OLTA V AS E BI R OIS S = 0 10 UT OP07E T N 1 INP U P IN VS = ±15V TA = 25°C 0 1 –75 –50 –25 0 25 50 75 100 125
009
1 10 100 1000
012
TEMPERATURE (°C) FREQUENCY (Hz)
00316- 00316- Figure 9. Input Bias Current vs. Temperature Figure 12. Total Input Noise Voltage vs. Frequency
2.5 10 V V S = ±15V S = ±15V TA = 25°C 2.0 A) n ( NT V) 1.5 CURRE ISE (µ T 1 O E S F 1.0 F MS N O OP07C R UT INP 0.5 OP07E 0 0.1 –100 –75 –50 –25 0 25 50 75 100
010
100 1k 10k 100k
013
TEMPERATURE (°C) BANDWIDTH (Hz)
00316- 00316- Figure 10. Input Offset Current vs. Temperature Figure 13. Input Wideband Noise vs. Bandwidth, 0.1 Hz to Frequency Indicated
130 REFERRED TO INPUT 5mV/CM AT OUTPUT 120 110 ) OP07C IV /D B) 100 d nV 0 0 2 RR ( ( 90 CM GE 80 OLTA V 70 60
011
1 10 100 1k 10k 100k
014
TIME (1s/DIV) FREQUENCY (Hz)
00316- 00316- Figure 11. Low Frequency Noise Figure 14. CMRR vs. Frequency Rev. G | Page 8 of 16 Document Outline Features Applications General Description Pin Configuration Revision History Specifications OP07E Electrical Characteristics OP07C Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Typical Applications Applications Information Outline Dimensions Ordering Guide
