Datasheet MBN52832 (Murata) - 7
ПроизводительMurata
ОписаниеBLE Module
Страниц / Страница34 / 7 — 2 Mechanical Specification. 2.1 Module Dimensions. Table 2.1: Module …
2 Mechanical Specification. 2.1 Module Dimensions. Table 2.1: Module Dimensions. Parameter. Typical. Unit. 2.2 Top and Side View
2 Mechanical Specification 2.1 Module Dimensions Table 2.1: Module Dimensions Parameter Typical Unit 2.2 Top and Side View
25 предложений от 11 поставщиков
Высокочастотная техника и средства высокочастотной идентификации Модули РЧ-трансиверов
WSM-BL241-ADA-008
Murata
552 ₽
Зенер
Россия и страны ТС
WSM-BL241-ADA-008
от 592 ₽
WSM-BL241-ADA-008DK
Murata
3 178 ₽
Hi-Tech Circuit Group
WSM-BL241-ADA-008DK
Murata
Dimension (L x W x H) 7.4 ±0.2mm x 7.0 ±0.2mm x 0.9 (max) mm
7.4mm typ. Pin 1 0.9mm max. 7.0mm typ.
Figure 2.1 Module Top and Side View (Unit: mm)
Copyright © Murata Manufacturing Co., Ltd. All rights reserved. October 2017 MBN52832 Data Sheet, v1.4, 02/06/2020 Page 7 of 34
www.murata.com
Document Outline Revision History Table of Contents 1 Introduction 1.1 Features 1.2 Applications 1.3 Block Diagram 1.4 Acronyms 1.5 References 2 Mechanical Specification 2.1 Module Dimensions 2.2 Top and Side View 2.3 PCB Footprint Top View 2.4 Pin Configuration 3 DC Electrical Specification 3.1 Typical Power Consumption 4 RF Specification 5 Environmental Specification 5.1 Absolute Maximum Rating 5.2 Recommended Operating Condition 6 Power Sequence 7 Application Information 7.1 Recommended PCB Landing Pattern 7.2 Host PCB Layout Recommendations 7.3 Layout Guidance for Using Internal PCB Antenna 7.4 Layout Guidance for Microstrip Design And External Antenna 8 Application Reference 9 Assembly Information 10 Packaging and Marking Information 10.1 Dimensions of Tape (Plastic tape) 10.2 Dimensions of Reel 10.3 Taping Diagrams 10.4 Leader and Tail tape 10.5 Peeling Force 10.6 PACKAGE (Humidity proof Packaging) 10.7 Module Marking Information 10.8 Moisture Sensitivity Level 11 Regulatory Information 11.1 FCC Notice (USA) 11.2 FCC Labeling Requirements 11.3 IC Notice (Canada) 11.4 IC Labeling Requirements 11.5 ESTI compliance (Europe) 11.6 RF Exposure 11.6.1 Using on-board PCB antenna 11.6.2 Using external antenna 11.7 KC Certificate Notice 12 RoHS Information 13 Ordering Information 14 Notice 14.1 Storage Conditions 14.2 Handling Conditions 14.3 Standard PCB Design (Land Pattern and Dimensions) 14.4 Notice for Chip Placer 14.5 Operational Environment Conditions 14.6 Input Power Capacity 15 Preconditions To Use Murata Products
