Datasheet LTC3882 (Analog Devices) - 8
ОписаниеDual Output PolyPhase Step-Down DC/DC Voltage Mode Controller with Digital Power System Management
Страниц / Страница106 / 8 — ELECTRICAL CHARACTERISTICS Note 1:. Note 2:. Note 5:. Note 6:. Note 7:. …
ВерсияC
Формат / Размер файлаPDF / 3.0 Мб
ELECTRICAL CHARACTERISTICS Note 1:. Note 2:. Note 5:. Note 6:. Note 7:. Note 8:. Note 3:. Note 9:. Note 10:. Note 11:. Note 4:
ELECTRICAL CHARACTERISTICS Note 1: Note 2: Note 5: Note 6: Note 7: Note 8: Note 3: Note 9: Note 10: Note 11: Note 4:
LTC3882CIUJ#TRPBF
727GS
LTC3882CIUJ#TRPBF
LTC3882CIUJ#TRPBF
LTC3882
Stresses beyond those listed under Absolute Maximum Ratings process controls. Minimum retention applies only for devices cycled less may cause permanent damage to the device. Exposure to any Absolute than the minimum endurance specification. EEPROM read commands Maximum Rating condition for extended periods may affect device (e.g. RESTORE_USER_ALL) are valid over the entire specified operating reliability and lifetime. junction temperature range.
Note 2:
The LTC3882 is tested under pulsed load conditions such that
Note 5:
All currents into device pins are positive; all currents out of device TJ ≈ TA. The LTC3882E is guaranteed to meet performance specifications pins are negative. All voltages are referenced to GND unless otherwise from 0°C to 85°C. Specifications over the –40°C to 125°C operating specified. junction temperature range are assured by design, characterization and
Note 6:
Minimum EEPROM endurance, retention and mass write time correlation with statistical process controls. The LTC3882I is guaranteed specifications apply when writing data with 3.15V ≤ VDD33 ≤ 3.45V. over the full –40°C to 125°C operating junction temperature range. EEPROM read commands are valid over the entire specified VDD33 Junction temperature TJ is calculated in °C from the ambient temperature operating range. TA and power dissipation PD according to the formula:
Note 7:
Specified VOUT accuracy with AVP = 0% requires servo mode to TJ = TA + (PD • θJA) be set with MFR_PWM_MODE_LTC3882 command bit 6. Performance is where θJA is the package thermal impedance. Note that the maximum guaranteed by testing the LTC3882 in a feedback loop that servos VOUT to ambient temperature consistent with these specifications is determined by a specified value. specific operating conditions in conjunction with board layout, the rated
Note 8:
ADC tested with PWMs disabled. Comparable capability package thermal impedance and other environmental factors. Refer to the demonstrated by in-circuit evaluations. Total Unadjusted Error includes all Applications Information section. gain and linearity errors, as well as offsets.
Note 3:
This IC includes overtemperature protection that is intended to
Note 9:
Internal 32-bit calculations using 16-bit ADC results are limited to protect the device during momentary overload conditions. The maximum 10-bit resolution by PMBus Linear 11-bit data format. rated junction temperature will be exceeded when this protection is active.
Note 10:
Limits guaranteed by TSNS voltage and current measurements Continuous operation above the specified absolute maximum operating during test, including ADC readback. junction temperature may impair device reliability or permanently damage the device.
Note 11:
Data conversion is done in round robin fashion. All inputs signals are continuously scanned in sequence resulting in a typical conversion
Note 4:
EEPROM endurance, retention and mass write times are latency of 90ms. guaranteed by design, characterization and correlation with statistical Rev. C 8 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Block Diagram Test Circuit Timing Diagram Operation Overview Main Control Loop Power-Up and Initialization Soft-Start Time-Based Output Sequencing Output Ramping Control Voltage-Based Output Sequencing Output Disable Minimum Output Disable Times Output Short Cycle Light Load Current Operation Switching Frequency and Phase PolyPhase Load Sharing Active Voltage Positioning Input Supply Monitoring Output Voltage Sensing and Monitoring Output Current Sensing and Monitoring External and Internal Temperature Sense Resistor Configuration Pins Internal EEPROM with ECC and CRC Fault Detection Input Supply Faults Hardwired PWM Response to VOUT Faults Power Good Indication Hardwired PWM Response to IOUT Faults Hardwired PWM Response to Temperature Faults Hardwired PWM Response to Timing Faults External Faults Fault Handling Status Registers and ALERT Masking Mapping Faults to GPIO Pins Other GPIO Uses Fault Logging Factory Default Operation Serial Interface Serial Bus Addressing Serial Bus Timeout Serial Communication Errors PMBus Command Summary PMBus Commands Data Formats Applications Information Efficiency Considerations PWM Frequency and Inductor Selection Power MOSFET Selection MOSFET Driver Selection Using PWM Protocols CIN Selection COUT Selection Feedback Loop Compensation PCB Layout Considerations Output Current Sensing Output Voltage Sensing Soft-Start and Stop Time-Based Output Sequencing and Ramping Voltage-Based Output Sequencing Using Output Voltage Servo Using AVP PWM Frequency Synchronization PolyPhase Operation and Load Sharing External Temperature Sense Resistor Configuration Pins Internal Regulator Outputs IC Junction Temperature Derating EEPROM Retention at Temperature Configuring Open-Drain Pins PMBus Communication and Command Processing Status and Fault Log Management LTpowerPlay – An Interactive Digital Power GUI Interfacing to the DC1613 Design Example PMBus COMMAND DETAILS Addressing and Write Protect PAGE PAGE_PLUS_WRITE PAGE_PLUS_READ WRITE_PROTECT MFR_ADDRESS MFR_RAIL_ADDRESS General Device Configuration PMBUS_REVISION CAPABILITY On, Off and Margin Control ON_OFF_CONFIG MFR_CONFIG_ALL_LTC3882 OPERATION MFR_RESET PWM Configuration FREQUENCY_SWITCH MFR_PWM_CONFIG_LTC3882 MFR_CHAN_CONFIG_LTC3882 MFR_PWM_MODE_LTC3882 Input Voltage and Limits VIN_ON VIN_OFF VIN_OV_FAULT_LIMIT VIN_UV_WARN_LIMIT Output Voltage and Limits VOUT_MODE VOUT_COMMAND MFR_VOUT_MAX VOUT_MAX MFR_VOUT_AVP VOUT_MARGIN_HIGH VOUT_MARGIN_LOW VOUT_OV_FAULT_LIMIT VOUT_OV_WARN_LIMIT VOUT_UV_WARN_LIMIT VOUT_UV_FAULT_LIMIT Output Current and Limits IOUT_CAL_GAIN MFR_IOUT_CAL_GAIN_TC IOUT_OC_FAULT_LIMIT IOUT_OC_WARN_LIMIT Output Timing, Delays, and Ramping MFR_RESTART_DELAY TON_DELAY TON_RISE TON_MAX_FAULT_LIMIT VOUT_TRANSITION_RATE TOFF_DELAY TOFF_FALL TOFF_MAX_WARN_LIMIT External Temperature and Limits MFR_TEMP_1_GAIN MFR_TEMP_1_OFFSET OT_FAULT_LIMIT OT_WARN_LIMIT Status Reporting STATUS_BYTE UT_FAULT_LIMIT STATUS_WORD STATUS_VOUT STATUS_IOUT STATUS_INPUT STATUS_TEMPERATURE STATUS_CML STATUS_MFR_SPECIFIC MFR_PADS_LTC3882 MFR_COMMON MFR_INFO CLEAR_FAULTS Telemetry READ_VIN MFR_VIN_PEAK READ_VOUT MFR_VOUT_PEAK READ_IOUT MFR_IOUT_PEAK READ_POUT READ_TEMPERATURE_1 MFR_TEMPERATURE_1_PEAK READ_TEMPERATURE_2 MFR_TEMPERATURE_2_PEAK READ_DUTY_CYCLE READ_FREQUENCY MFR_CLEAR_PEAKS Fault Response and Communication VIN_OV_FAULT_RESPONSE VOUT_OV_FAULT_RESPONSE VOUT_UV_FAULT_RESPONSE IOUT_OC_FAULT_RESPONSE OT_FAULT_RESPONSE UT_FAULT_RESPONSE MFR_OT_FAULT_RESPONSE TON_MAX_FAULT_RESPONSE MFR_RETRY_DELAY SMBALERT_MASK MFR_GPIO_PROPAGATE_LTC3882 MFR_GPIO_RESPONSE MFR_FAULT_LOG Fault Log Operation MFR_FAULT_LOG_CLEAR EEPROM User Access STORE_USER_ALL RESTORE_USER_ALL MFR_COMPARE_USER_ALL MFR_FAULT_LOG_STORE MFR_EE_xxxx USER_DATA_0x Unit Identification MFR_ID MFR_MODEL MFR_SERIAL MFR_SPECIAL_ID Typical Applications Package Description Revision History Typical Application Related Parts
