Оптопары и оптореле Megawin
Datasheet LTC3890 (Analog Devices) - 3
Описание60V Low IQ, Dual, 2-Phase Synchronous Step-Down DC/DC Controller
Страниц / Страница40 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
ВерсияD
Формат / Размер файлаPDF / 805 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply over the specified operating
ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the specified operating
12 предложений от 11 поставщиков
Чип стабилизации напряжения, 60V Low IQ, Dual, 2-Phase Synchronous Step-Down DC-DC Controller
LTC3890MPUH-2#TRPBF
1 619 ₽
LTC3890MPUH#TRPBF
2 357 ₽
LTC3890MPUH#TRPBF
LTC3890MPUH TRPBF
LTC3890
l
denotes the specifications which apply over the specified operating junction temperature range, otherwise specifications are at TA = 25°C. VIN = 12V, VRUN1,2 = 5V, EXTVCC = 0V unless otherwise noted. (Note 2) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Input Supply Operating Voltage Range 4 60 V VFB1,2 Regulated Feedback Voltage (Note 4) ITH1,2 Voltage = 1.2V –40°C to 85°C, All Grades 0.792 0.800 0.808 V LTC3890E, LTC3890I l 0.788 0.800 0.812 V LTC3890H, LTC3890MP l 0.786 0.800 0.812 V IFB1,2 Feedback Current (Note 4) ±5 ±50 nA VREFLNREG Reference Voltage Line Regulation (Note 4) VIN = 4.5V to 60V 0.002 0.02 %/V VLOADREG Output Voltage Load Regulation (Note 4) Measured in Servo Loop, l 0.01 0.1 % ∆ITH Voltage = 1.2V to 0.7V (Note 4) Measured in Servo Loop, l –0.01 –0.1 % ∆ITH Voltage = 1.2V to 2V gm1,2 Transconductance Amplifier gm (Note 4) ITH1,2 = 1.2V, Sink/Source = 5µA 2 mmho IQ Input DC Supply Current (Note 5) Pulse-Skipping or Forced Continuous RUN1 = 5V and RUN2 = 0V, VFB1 = 0.83V or 1.3 mA Mode (One Channel On) RUN1 = 0V and RUN2 = 5V, VFB2 = 0.83V Pulse-Skipping or Forced Continuous RUN1,2 = 5V, VFB1,2 = 0.83V (No Load) 2 mA Mode (Both Channels On) Sleep Mode (One Channel On) RUN1 = 5V and RUN2 = 0V, VFB1 = 0.83V (No Load) or 50 75 µA RUN1 = 0V and RUN2 = 5V, VFB2 = 0.83V (No Load) Sleep Mode (Both Channels On) RUN1,2 = 5V, VFB1,2 = 0.83V (No Load) 60 100 µA Shutdown RUN1,2 = 0V 14 25 µA UVLO Undervoltage Lockout INTVCC Ramping Up l 3.92 4.2 V INTVCC Ramping Down l 3.6 3.80 4.0 V Feedback Overvoltage Protection Measured at VFB1,2, Relative to Regulated VFB1,2 7 10 13 % I + SENSE SENSE+ Pin Current Each Channel ±1 µA I – SENSE SENSE– Pins Current Each Channel V – SENSE < INTVCC – 0.5V ±1 µA V – SENSE > INTVCC + 0.5V 700 µA Maximum TG1, 2 Duty Factor In Dropout 98 99 % ITRACK/SS1,2 Soft-Start Charge Current VTRACK/SS1,2 = 0V 0.7 1.0 1.4 µA VRUN1 RUN1 Pin On Threshold VRUN1 Rising l 1.15 1.21 1.27 V VRUN2 RUN2 Pin On Threshold VRUN2 Rising l 1.20 1.25 1.30 V RUN1,2 Pin Hysteresis 50 mV VSENSE(MAX) Maximum Current Sense Threshold VFB1,2 = 0.7V, VSENSE1–,2– = 3.3V, ILIM = 0 l 22 30 36 mV VFB1,2 = 0.7V, VSENSE1–,2– = 3.3V, ILIM = INTVCC l 43 50 57 mV VFB1,2 = 0.7V, VSENSE1–,2– = 3.3V, ILIM = FLOAT l 64 75 85 mV
Gate Driver
TG1,2 Pull-Up On-Resistance 2.5 Ω TG1,2 Pull-Down On-Resistance 1.5 Ω BG1,2 Pull-Up On-Resistance 2.4 Ω BG1,2 Pull-Down On-Resistance 1.1 Ω TG Transition Time: (Note 6) TG1,2 tr Rise Time CLOAD = 3300pF 25 ns TG1,2 tf Fall Time CLOAD = 3300pF 16 ns BG Transition Time: (Note 6) BG1,2 tr Rise Time CLOAD = 3300pF 28 ns BG1,2 tf Fall Time CLOAD = 3300pF 13 ns Rev. D For more information www.analog.com 3 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Functional Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
