Datasheet MAX6001, MAX6002, MAX6003, MAX6004, MAX6005 (Analog Devices) - 4
ОписаниеLow-Cost, Low-Power, Low-Dropout, SOT23-3 Voltage References
Страниц / Страница12 / 4 — Low-Cost, Low-Power, Low-Dropout, SOT23-3 Voltage References. ELECTRICAL …
Формат / Размер файлаPDF / 200 Кб
Low-Cost, Low-Power, Low-Dropout, SOT23-3 Voltage References. ELECTRICAL CHARACTERISTICS—MAX6003. PARAMETER. SYMBOL. CONDITIONS
Low-Cost, Low-Power, Low-Dropout, SOT23-3 Voltage References ELECTRICAL CHARACTERISTICS—MAX6003 PARAMETER SYMBOL CONDITIONS
V-Ref Precision 2.5V 0.4mA 3-Pin SOT-23 T/R
MAX6002EUR/V+T
Maxim
MAX6002EUR/V+T
Maxim
MAX6002EUR/V+T
MAX6002EUR/V+T
(VIN = +5V, IOUT = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS OUTPUT
Output Voltage VOUT TA = +25°C 2.97 3.00 3.03 V Output Voltage Temperature TCVOUT 20 100 ppm/°C Coefficient (Note 2) ∆VOUT/ Line Regulation ∆ (VOUT + 0.2V) ≤ VIN ≤ 12.6V 20 220 µV/V VIN ∆VOUT/ Sourcing: 0 ≤ IOUT ≤ 400µA 0.14 0.90 Load Regulation ∆ µV/µA IOUT Sinking: -400µA ≤ IOUT ≤ 0 0.18 1.10 Dropout Voltage VIN - IOUT = 400µA 100 200 mV (Note 5) VOUT Short to GND 4 OUT Short-Circuit Current ISC mA Short to IN 4
MAX6001–MAX6005
Temperature Hysteresis ∆VOUT/ 130 ppm (Note 3) time ∆VOUT/ ppm/ Long-Term Stability 1,000 hours at TA = +25°C 50 time 1,000hrs
DYNAMIC
f = 0.1Hz to 10Hz 75 µVp-p Noise Voltage eOUT f = 10Hz to 10kHz 150 µVRMS ∆VOUT/ Ripple Rejection ∆ VIN = 5V ±100mV, f = 120Hz 80 dB VIN Turn-On Settling Time tR To VOUT = 0.1% of final value, COUT = 50pF 100 µs Capacitive-Load Stability Range COUT (Note 4) 0 2.2 nF
INPUT
Supply Voltage Range VIN Guaranteed by line-regulation test VOUT + 0.2 12.6 V Quiescent Supply Current IIN 27 45 µA Change in Supply Current IIN/VIN (VOUT + 0.2V) ≤ VIN ≤ 12.6V 0.8 2.6 µA/V
4 _______________________________________________________________________________________
