Datasheet 1004795, 1004796 (AVX) - 8
ПроизводительAVX
ОписаниеUniversal Broadband FR4 Embedded LTE / 5G / LPWA Antenna
Страниц / Страница19 / 8 — Part No. 1004795 / 1004796. 1004795 / 1004796 Universal Broadband …
Формат / Размер файлаPDF / 3.0 Мб
Part No. 1004795 / 1004796. 1004795 / 1004796 Universal Broadband Embedded LTE Antenna Specifications
Part No 1004795 / 1004796 1004795 / 1004796 Universal Broadband Embedded LTE Antenna Specifications
30 предложений от 10 поставщиков
CELLULAR/LTE ANTENNA, 2W, 600MHZ-2.7GHZ
Зенер
Россия и страны ТС
1004795
от 134 ₽
1004795
AVX
от 451 ₽
1004795-EC646-01
Kyocera
от 5 839 ₽
Hi-Tech Circuit Group
1004795-EC646-01
Kyocera AVX
DATASHEET |
Part No. 1004795 / 1004796 1004795 / 1004796 Universal Broadband Embedded LTE Antenna Specifications. Ethertronics produces a wide variety of standard and custom antennas to meet user needs. Antenna Layout (1004795)
Typical layout dimensions (mm) Pin #6 Pin #5 Pin #4 Pin #3 Pin #1 Pin #2 Pin #7 Pin #8 Antenna 2500-2700 MHz Tuning Outline [1] • Additional VIAS: Diam. 0.4mm to be placed around antenna, (no vias on transmission lines). • Via holes must be covered by solder mask Pi Matching Pin Descriptions Network Pin# Description 50Ω Transmission line [2] 1 Feed 2 Antenna Tuning 3 Dummy Pad 4 Dummy Pad 5 Antenna Tuning 6 Dummy Pad 7 Dummy Pad 8 Dummy Pad *1004796 uses the same layout but mirrored. Default Pi Matching Network values with instructions can be found under Antenna Matching Network. [3] (698-960 MHz & 1710-2400 MHz Tuning) [4] [5] tel +(1) 858.550.3820 | fax +(1) 858.550.3821 © 2020 Ethertronics email: eth.info@avx.com 5501 Oberlin Drive, Suite 100 San Diego, CA 92121 - USA
