Datasheet VCNL3036X01 (Vishay) - 2
ПроизводительVishay
ОписаниеHigh Resolution Digital Proximity Sensor With I2C Interface
Страниц / Страница16 / 2 — VCNL3036X01. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. SYMBOL. …
Формат / Размер файлаPDF / 239 Кб
VCNL3036X01. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. SYMBOL. MIN. MAX. UNIT. RECOMMENDED OPERATING CONDITIONS
VCNL3036X01 ABSOLUTE MAXIMUM RATINGS PARAMETER TEST CONDITION SYMBOL MIN MAX UNIT RECOMMENDED OPERATING CONDITIONS
30 предложений от 7 поставщиков
Фотодатчики Окружающего Света
VCNL3036X01-GS18от 25 ₽
Зенер
Россия и страны ТС
VCNL3036X01-GS18от 165 ₽
VCNL3036X01-GS18193 ₽
Эиком
VCNL3036X01-GS18от 263 ₽
VCNL3036X01
www.vishay.com Vishay Semiconductors
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. MAX. UNIT
Supply voltage VDD 2.5 3.6 V Operation temperature range Tamb -40 +105 °C Storage temperature range Tstg -40 +110 °C
Supply voltage VDD 2.5 3.6 V Operation temperature range Tamb -40 +105 °C I2C bus operating frequency f(I2CCLK) 10 400 kHz
PIN DESCRIPTIONS PIN ASSIGNMENT SYMBOL TYPE FUNCTION
1 VDD - Power supply input 2 SCL I I2C digital bus clock input 3 GND - Ground 4 IRED3 I Cathode (IRED3) connection 5 IRED2 I Cathode (IRED2) connection 6 IRED1 I Cathode (IRED1) connection 7 INT O Interrupt pin 8 SDA I / O (open drain) I2C data bus data input / output
BASIC CHARACTERISTICS
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Supply voltage VDD 2.5 - 3.6 V Excluded LED driving IDD - 300 - μA Supply current Light condition = dark, VDD = 3.3 V IDD (SD) - 0.2 - μA I2C supply voltage VPULL UP 1.8 - 5.5 V PS enable IPSSD - 200 - μA Logic high VIH 1.55 - - VDD = 3.3 V V Logic low VIL - - 0.4 I2C signal input Logic high VIH 1.4 - - VDD = 2.6 V V Logic low VIL - - 0.4 4096 / Full PS counts 12-bit / 16-bit resolution - - steps 65 535 PS detection range Kodak gray card (1)(2) 0 - 500 mm Operating temperature range Tamb -40 - +105 °C LED anode voltage - - 5.5 V IRED driving current - - 200 mA
Notes
(1) Depending on external IRED (2) Part should be operated in dark condition (not in direct sunlight) Rev. 1.0, 12-Aug-2020
2
Document Number: 84937 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
