Datasheet VCNL3036X01 (Vishay) - 3
ПроизводительVishay
ОписаниеHigh Resolution Digital Proximity Sensor With I2C Interface
Страниц / Страница16 / 3 — VCNL3036X01. I2C BUS TIMING CHARACTERISTICS. STANDARD MODE. FAST MODE. …
Формат / Размер файлаPDF / 239 Кб
VCNL3036X01. I2C BUS TIMING CHARACTERISTICS. STANDARD MODE. FAST MODE. PARAMETER. SYMBOL. UNIT. MIN. MAX
VCNL3036X01 I2C BUS TIMING CHARACTERISTICS STANDARD MODE FAST MODE PARAMETER SYMBOL UNIT MIN MAX
30 предложений от 7 поставщиков
Фотодатчики Окружающего Света
VCNL3036X01-GS18
от 25 ₽
VCNL3036X01-GS18
79 ₽
Зенер
Россия и страны ТС
VCNL3036X01-GS18
от 165 ₽
Эиком
VCNL3036X01-GS18
от 263 ₽
VCNL3036X01
www.vishay.com Vishay Semiconductors
(Tamb = 25 °C, unless otherwise specified)
STANDARD MODE FAST MODE PARAMETER SYMBOL UNIT MIN. MAX. MIN. MAX.
Clock frequency f(SMBCLK) 10 100 10 400 kHz Bus free time between start and stop condition t(BUF) 4.7 - 1.3 - μs Hold time after (repeated) start condition; t after this period, the first clock is generated (HDSTA) 4.0 - 0.6 - μs Repeated start condition setup time t(SUSTA) 4.7 - 0.6 - μs Stop condition setup time t(SUSTO) 4.0 - 0.6 - μs Data hold time t(HDDAT) - 3450 - 900 ns Data setup time t(SUDAT) 250 - 100 - ns I2C clock (SCK) low period t(LOW) 4.7 - 1.3 - μs I2C clock (SCK) high period t(HIGH) 4.0 - 0.6 - μs Clock / data fall time t(F) - 300 - 300 ns Clock / data rise time t(R) - 1000 - 300 ns t t t (LOW) (R) (F) VIH I2C BUS CLOCK VIL (SCL) t t t (HDSTA) (HIGH) (SUSTA) t(SUSTO) t(BUF) t t (HDDAT) (SUDAT) I2C BUS VIH DATA (SDA) VIL { { { { P S S P Stop condition Start condition Start Stop t(LOSEXT) SCL SDA ACK ACK t t t (LOWMEXT) (LOWMEXT) (LOWMEXT) I2C BUS CLOCK (SCL) I2C BUS DATA (SDA) Fig. 1 - I2C Bus Timing Diagram Rev. 1.0, 12-Aug-2020
3
Document Number: 84937 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
