Datasheet FT232R (FTDI) - 3
ПроизводительFTDI
ОписаниеUSB UART IC
Страниц / Страница40 / 3 — FT232R USB UART IC Datasheet. Version 2.16. 1.2 Part Numbers. Part …
Версия2.16
FT232R USB UART IC Datasheet. Version 2.16. 1.2 Part Numbers. Part Number. Package. Note:. 1.3 USB Compliant
FT232R USB UART IC Datasheet Version 2.16 1.2 Part Numbers Part Number Package Note: 1.3 USB Compliant
39 предложений от 21 поставщиков
Чип интерфейса, USB-to-UART 1CH 256Byte FIFO 5V 32Pin QFN EP T/R
FT232RQ-REEL
FTDI
от 534 ₽
Триема
FT232RQ-REEL
FTDI
630 ₽
Hi-Tech Circuit Group
FT232RQ-REEL
ТаймЧипс
FT232RQ-REEL
FTDI
Document No.: FT_000053 Clearance No.: FTDI# 38
FT232RQ-xxxx 32 Pin QFN FT232RL-xxxx 28 Pin SSOP
Note:
Packing codes for xxxx is: - Reel: Taped and Reel, (SSOP is 2,000pcs per reel, QFN is 6,000pcs per reel). - Tube: Tube packing, 47pcs per tube (SSOP only) - Tray: Tray packing, 490pcs per tray (QFN only) For example: FT232RQ-Reel is 6,000pcs taped and reel packing
1.3 USB Compliant
The FT232R is fully compliant with the USB 2.0 specification and has been given the USB-IF Test-ID (TID) 40680004 (Rev B) and 40770018 (Rev C). Copyright © Future Technology Devices International Limited 3 Document Outline 1 Typical Applications 1.1 Driver Support 1.2 Part Numbers 1.3 USB Compliant 2 FT232R Block Diagram 3 Device Pin Out and Signal Description 3.1 28-LD SSOP Package 3.2 SSOP Package Pin Out Description 3.3 QFN-32 Package 3.4 QFN-32 Package Signal Description 3.5 CBUS Signal Options 4 Function Description 4.1 Key Features 4.2 Functional Block Descriptions 5 Devices Characteristics and Ratings 5.1 Absolute Maximum Ratings 5.2 DC Characteristics 5.3 EEPROM Reliability Characteristics 5.4 Internal Clock Characteristics 5.5 Thermal Characteristics 6 USB Power Configurations 6.1 USB Bus Powered Configuration 6.2 Self Powered Configuration 6.3 USB Bus Powered with Power Switching Configuration 6.4 USB Bus Powered with Selectable External Logic Supply 7 Application Examples 7.1 USB to RS232 Converter 7.2 USB to RS485 Converter 7.3 USB to RS422 Converter 7.4 USB to MCU UART Interface 7.5 LED Interface 7.6 Using the External Oscillator 8 Internal EEPROM Configuration 9 Package Parameters 9.1 SSOP-28 Package Dimensions 9.2 QFN-32 Package Dimensions 9.3 Solder Reflow Profile 10 Alternative Parts 11 Contact Information Appendix A – References Document References Acronyms and Abbreviations Appendix B – List of Figures and Tables List of Figures List of Tables Appendix C – Revision History
