Datasheet MC1488 (ON Semiconductor) - 9
Производитель | ON Semiconductor |
Описание | Quad Line EIA-232D Driver |
Страниц / Страница | 14 / 9 — PACKAGE DIMENSIONS. PDIP−14. SCALE 1:1. NOTE 8. TOP VIEW. END VIEW. WITH … |
Версия | 9 |
Формат / Размер файла | PDF / 343 Кб |
Язык документа | английский |
PACKAGE DIMENSIONS. PDIP−14. SCALE 1:1. NOTE 8. TOP VIEW. END VIEW. WITH LEADS CONSTRAINED. NOTE 5. INCHES. MILLIMETERS. DIM. MIN. MAX. NOTE 3
14 предложений от 14 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы |
| MC1488MG Rochester Electronics | 28 ₽ | |
| MC1488MG ON Semiconductor | 28 ₽ | |
| MC1488MG ON Semiconductor | по запросу | |
MECHANICAL CASE OUTLINE
PACKAGE DIMENSIONS PDIP−14
CASE 646−06 ISSUE S DATE 22 APR 2015 1
SCALE 1:1
NOTES: 1. DIMENSIONING AND TOLERANCING PER ASME Y14.5M, 1994.
D A
2. CONTROLLING DIMENSION: INCHES. 3. DIMENSIONS A, A1 AND L ARE MEASURED WITH THE PACK-
14 8 E
AGE SEATED IN JEDEC SEATING PLANE GAUGE GS−3.
H
4. DIMENSIONS D, D1 AND E1 DO NOT INCLUDE MOLD FLASH OR PROTRUSIONS. MOLD FLASH OR PROTRUSIONS ARE NOT TO EXCEED 0.10 INCH.
E1
5. DIMENSION E IS MEASURED AT A POINT 0.015 BELOW DATUM PLANE H WITH THE LEADS CONSTRAINED PERPENDICULAR TO DATUM C. 6. DIMENSION eB IS MEASURED AT THE LEAD TIPS WITH THE
1 7
LEADS UNCONSTRAINED.
c NOTE 8 b2 B
7. DATUM PLANE H IS COINCIDENT WITH THE BOTTOM OF THE
TOP VIEW END VIEW
LEADS, WHERE THE LEADS EXIT THE BODY.
8. PACKAGE CONTOUR IS OPTIONAL (ROUNDED OR SQUARE
NOTE 5
CORNERS).
A2 A INCHES MILLIMETERS DIM MIN MAX MIN MAX NOTE 3 A
−−−− 0.210 −−− 5.33
L A1
0.015 −−−− 0.38 −−−
A2
0.115 0.195 2.92 4.95
SEATING b
0.014 0.022 0.35 0.56
A1 PLANE b2
0.060 TYP 1.52 TYP
C C
0.008 0.014 0.20 0.36
M D
0.735 0.775 18.67 19.69
D1 D1
0.005 −−−− 0.13 −−−
e eB E
0.300 0.325 7.62 8.26
14X b END VIEW E1
0.240 0.280 6.10 7.11
e
0.100 BSC 2.54 BSC
NOTE 6
0.010 C A
SIDE VIEW
M M B M
eB
−−−− 0.430 −−− 10.92
L
0.115 0.150 2.92 3.81
M
−−−− 10 ° −−− 10 °
GENERIC MARKING DIAGRAM*
14 XXXXXXXXXXXX XXXXXXXXXXXX AWLYYWWG
STYLES ON PAGE 2
1 XXXXX = Specific Device Code A = Assembly Location WL = Wafer Lot YY = Year WW = Work Week G = Pb−Free Package *This information is generic. Please refer to device data sheet for actual part marking. Pb−Free indicator, “G” or microdot “ G”, may or may not be present.
DOCUMENT NUMBER: 98ASB42428B
Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red.
DESCRIPTION: PDIP−14 PAGE 1 OF 2
ON Semiconductor and are trademarks of Semiconductor Components Industries, LLC dba ON Semiconductor or its subsidiaries in the United States and/or other countries. ON Semiconductor reserves the right to make changes without further notice to any products herein. ON Semiconductor makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does ON Semiconductor assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. ON Semiconductor does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 2019 www.onsemi.com
