Datasheet 2N3055, MJ2955 (ON Semiconductor) - 4
ПроизводительON Semiconductor
ОписаниеComplementary Silicon Power Transistors
Страниц / Страница5 / 4 — PACKAGE DIMENSIONS. TO−204 (TO−3). CASE 1−07. ISSUE Z. DATE 05/18/1988. …
Версия6
Формат / Размер файлаPDF / 123 Кб
PACKAGE DIMENSIONS. TO−204 (TO−3). CASE 1−07. ISSUE Z. DATE 05/18/1988. SCALE 1:1. −T− SEATING. PLANE. INCHES. MILLIMETERS. D 2 PL. DIM. MIN. MAX
PACKAGE DIMENSIONS TO−204 (TO−3) CASE 1−07 ISSUE Z DATE 05/18/1988 SCALE 1:1 −T− SEATING PLANE INCHES MILLIMETERS D 2 PL DIM MIN MAX
39 предложений от 20 поставщиков
TRANS NPN 60V 15A TO3. Bipolar (BJT) Transistor NPN 60V 15A 2.5MHz 115W Through Hole TO-204 (TO-3). Transistors - Bipolar (BJT)...
2N3055G
194 ₽
2N3055G
от 425 ₽
LifeElectronics
2N3055G
727GS
2N3055G
MECHANICAL CASE OUTLINE
NOTES:
A
1. DIMENSIONING AND TOLERANCING PER ANSI
N
Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH.
C
3. ALL RULES AND NOTES ASSOCIATED WITH
−T− SEATING
REFERENCED TO-204AA OUTLINE SHALL APPLY.
PLANE E INCHES MILLIMETERS K D 2 PL DIM MIN MAX MIN MAX A
1.550 REF 39.37 REF 0.13 (0.005) M T Q M Y M
B
--- 1.050 --- 26.67
C
0.250 0.335 6.35 8.51
D
0.038 0.043 0.97 1.09
U −Y− E
0.055 0.070 1.40 1.77
V L G
0.430 BSC 10.92 BSC
H
0.215 BSC 5.46 BSC
2 K
0.440 0.480 11.18 12.19
G B L
0.665 BSC 16.89 BSC
H 1 N
--- 0.830 --- 21.08
Q
0.151 0.165 3.84 4.19
U
1.187 BSC 30.15 BSC
−Q− V
0.131 0.188 3.33 4.77 0.13 (0.005) M T Y M STYLE 1: STYLE 2: STYLE 3: STYLE 4: STYLE 5: PIN 1. BASE PIN 1. BASE PIN 1. GATE PIN 1. GROUND PIN 1. CATHODE 2. EMITTER 2. COLLECTOR 2. SOURCE 2. INPUT 2. EXTERNAL TRIP/DELAY CASE: COLLECTOR CASE: EMITTER CASE: DRAIN CASE: OUTPUT CASE: ANODE STYLE 6: STYLE 7: STYLE 8: STYLE 9: PIN 1. GATE PIN 1. ANODE PIN 1. CATHODE #1 PIN 1. ANODE #1 2. EMITTER 2. OPEN 2. CATHODE #2 2. ANODE #2 CASE: COLLECTOR CASE: CATHODE CASE: ANODE CASE: CATHODE
and are trademarks of Semiconductor Components Industries, LLC (SCILLC). SCILLC reserves the right to make changes without further notice to any products herein. SCILLC makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does SCILLC assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in SCILLC data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. SCILLC does not convey any license under its patent rights nor the rights of others. SCILLC products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the SCILLC product could create a situation where personal injury or death may occur. Should Buyer purchase or use SCILLC products for any such unintended or unauthorized application, Buyer shall indemnify and hold SCILLC and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that SCILLC was negligent regarding the design or manufacture of the part. SCILLC is an Equal Opportunity/Affirmative Action Employer. © Semiconductor Components Industries, LLC, 2000
1
Case Outline Number:
January, 2000 − Rev. 07Z 1
