Datasheet TB9053FTG,TB9054FTG - Preliminary (Toshiba) - 4
ПроизводительToshiba
ОписаниеBi-CMOS Linear Integrated Circuit, Silicon Monolithic
Страниц / Страница36 / 4 — Preliminary. 5. Function description. 5.1. Motor drive output circuit
Preliminary 5 Function description 5.1 Motor drive output circuit
21 предложений от 6 поставщиков
Motor / Motion / Ignition Controllers & Drivers H-BRIDGE MTR DRV 2ch 5A/1ch 10A SPI, AEC-Q100/Q006, Power QFN40
Зенер
Россия и страны ТС
TB9053FTG(EL)
от 206 ₽
Элитан
TB9053FTG(EL)
Toshiba
451 ₽
TB9053FTG(EL)
Toshiba
494 ₽
Hi-Tech Circuit Group
TB9053FTG(EL)
link to page 4 link to page 6 link to page 10
Preliminary
TB9053FTG,TB9054FTG
In the specifications below, DT denotes a dead time and SB denotes a short brake at motor drive operations.
The output circuit operates in the following functions (Table 5.1). In Table 5.1 to Table 5.3, the following notation are used. X: Don’t Care, H: High, L: Low, Z: High Impedance. OSEL1 OSEL2 LARGE mode (combined 2 channels; 1 motor) L L Half mode H L SMALL mode (separate 2 channels; 2 motors) L H Prohibited mode (Motor output OFF) H H Note: The OSEL1 and OSEL2 pin inputs are latched when the initial diagnosis starts. If prohibited mode is entered, reset the VCC power supply (by lowering it below the VCC under-voltage POR detection voltage) to restart the IC.
5.1.1. 2-channel mode (SMALL mode) (OSEL1 = L and OSEL2 = H) Table 5.1 H-bridge motor function 1
PWM1 PWM2 EN1 ENB1 SLEEPB
OUT1 OUT2
Forward H L H L H
H L
Short brake L L H L H
L L
Reverse L H H L H
L H
Short brake H H H L H
H H
EN1 Disable X X L L H
Z Z
ENB1 Disable X X H H H
Z Z
Sleep mode X X X L/H L
Z Z
EN1 Disconnected X X Z X X
Z Z
ENB1 Disconnected X X X Z X
Z Z
PWM1 Disconnected Z L/H H L H
L L/H
PMM2 Disconnected L/H Z H L H
L/H L
PWM3 PWM4 EN2 ENB2 SLEEPB
OUT3 OUT4
Forward H L H L H
H L
L L
Reverse L H H L H
L H
H H
EN2 Disable X X L L H
Z Z
ENB2 Disable X X H H H
Z Z
Z Z
EN2 Disconnected X X Z X X
Z Z
ENB2 Disconnected X X X Z X
Z Z
PWM3 Disconnected Z L/H H L H
L L/H
PMM4 Disconnected L/H Z H L H
L/H L
Note: When changing the motor rotation from Forward to Reverse or vice versa, always insert a brake, which involves regeneration. Otherwise, the IC may be broken down. Note: When the current limit control is applied, the operation is different from the motor function table above. For details, refer to the current limit control (5.3). Note: The SLEEPB pin sets a low-power sleep mode. When SLEEPB = L, the system enters a sleep mode. When SLEEPB = H, the system cancels a sleep mode. Note: When SLEEPB = L, the ENB1/2 pins does not use OPEN, set the ENB1/2 pins to L or H. © 20 20 4 2020-12-10 Toshiba Electronic Devices & Storage Corporation
