Datasheet WP710A10YD5V (Kingbright) - 2
| Производитель | Kingbright |
| Описание | T-1 (3mm) Solid State Lamp |
| Страниц / Страница | 5 / 2 — WP710A10YD5V. ELECTRICAL / OPTICAL CHARACTERISTICS at TA=25°C. Value. … |
| Формат / Размер файла | PDF / 321 Кб |
WP710A10YD5V. ELECTRICAL / OPTICAL CHARACTERISTICS at TA=25°C. Value. Parameter. Symbol. Emitting Color. Unit. Typ. Max
14 предложений от 8 поставщиков Основной светодиод, Standard LEDs - Through Hole Yel 15mcd 588nm 40deg 5V resistor |
| WP710A10YD5V Kingbright | 9.57 ₽ | |
| WP710A10YD5V Kingbright | от 18 ₽ | |
| WP710A10YD5V Kingbright | по запросу | |
| WP710A10YD5V
| по запросу | |
WP710A10YD5V ELECTRICAL / OPTICAL CHARACTERISTICS at TA=25°C Value Parameter Symbol Emitting Color Unit Typ. Max.
Wavelength at Peak Emission VF = 5V λpeak Yellow 590 - nm Dominant Wavelength VF = 5V λdom [1] Yellow 588 - nm Spectral Bandwidth at 50% Φ REL MAX Δλ Yellow V 35 - nm F = 5V Forward Current VF = 5V IF Yellow 13 17.5 mA Reverse Current (VR = 5V) IR Yellow - 10 µA Notes: 1. The dominant wavelength (λd) above is the setup value of the sorting machine. (Tolerance λd : ±1nm. ) 2. Wavelength value is traceable to CIE127-2007 standards. 3. Excess driving current and / or operating temperature higher than recommended conditions may result in severe light degradation or premature failure.
ABSOLUTE MAXIMUM RATINGS at TA=25°C Parameter Symbol Value Unit
Power Dissipation PD 85 mW Reverse Voltage VR 5 V Junction Temperature Tj 110 °C Operating Temperature Top -40 to +70 °C Storage Temperature Tstg -40 to +85 °C Forward Voltage VF 6 V Electrostatic Discharge Threshold (HBM) - 3000 V Lead Solder Temperature [1] 260°C For 3 Seconds Lead Solder Temperature [2] 260°C For 5 Seconds Notes: 1. 2mm below package base. 2. 5mm below package base. 3. Relative humidity levels maintained between 40% and 60% in production area are recommended to avoid the build-up of static electricity – Ref JEDEC/JESD625-A and JEDEC/J-STD-033. © 2019 Kingbright. All Rights Reserved. Spec No: DSAL0566 / 1101029092 Rev No: V.10B Date: 11/19/2019 Page 2 / 5
