Datasheet WP710A10YD5V (Kingbright) - 5
| Производитель | Kingbright |
| Описание | T-1 (3mm) Solid State Lamp |
| Страниц / Страница | 5 / 5 — WP710A10YD5V. Lead Forming Procedures. PRECAUTIONARY NOTES |
| Формат / Размер файла | PDF / 321 Кб |
14 предложений от 8 поставщиков Основной светодиод, Standard LEDs - Through Hole Yel 15mcd 588nm 40deg 5V resistor |
| WP710A10YD5V Kingbright | 9.57 ₽ | |
| WP710A10YD5V Kingbright | 15 ₽ | |
| WP710A10YD5V Kingbright | от 18 ₽ | |
| WP710A10YD5V Kingbright | по запросу | |
WP710A10YD5V Lead Forming Procedures
1. Do not bend the leads more than twice. (Fig. 6 ) 2. During soldering, component covers and holders should leave clearance to avoid placing damaging stress on the LED during soldering. (Fig. 7) 3. The tip of the soldering iron should never touch the lens epoxy. 4. Through-hole LEDs are incompatible with reflow soldering. 5. If the LED will undergo multiple soldering passes or face other processes where the part may be subjected to intense heat, please check with Kingbright for compatibility.
PRECAUTIONARY NOTES
1. The information included in this document reflects representative usage scenarios and is intended for technical reference only. 2. The part number, type, and specifications mentioned in this document are subject to future change and improvement without notice. Before production usage customer should refer to the latest datasheet for the updated specifications. 3. When using the products referenced in this document, please make sure the product is being operated within the environmental and electrical limits specified in the datasheet. If customer usage exceeds the specified limits, Kingbright will not be responsible for any subsequent issues. 4. The information in this document applies to typical usage in consumer electronics applications. If customer's application has special reliability requirements or have life-threatening liabilities, such as automotive or medical usage, please consult with Kingbright representative for further assistance. 5. The contents and information of this document may not be reproduced or re-transmitted without permission by Kingbright. 6. All design applications should refer to Kingbright application notes available at https://www.KingbrightUSA.com/ApplicationNotes © 2019 Kingbright. All Rights Reserved. Spec No: DSAL0566 / 1101029092 Rev No: V.10B Date: 11/19/2019 Page 5 / 5
