Datasheet BAT46WJ (Nexperia) - 10
| Производитель | Nexperia |
| Описание | Schottky barrier diode |
| Страниц / Страница | 12 / 10 — Nexperia. BAT46WJ. Single Schottky barrier diode. 13. Legal information. … |
| Версия | 02062017 |
| Формат / Размер файла | PDF / 909 Кб |
Nexperia. BAT46WJ. Single Schottky barrier diode. 13. Legal information. 13.1 Data. sheet. status. Document status[1][2]
![Nexperia BAT46WJ Single Schottky barrier diode 13 Legal information 13.1 Data sheet status Document status[1][2]](https://www.rlocman.ru/datasheet/img.php?di=171445&p=9)
33 предложений от 13 поставщиков DIODE SCHOTTKY 100V 250MA SOD323. Diode Schottky 100V 250mA Surface Mount SOD-323F. Diodes - Rectifiers - Single |
| BAT46WJF Nexperia | от 1.31 ₽ | |
| BAT46WJF Nexperia | 4.39 ₽ | |
| BAT46WJF NXP | 13 ₽ | |
| BAT46WJF Nexperia | 24 ₽ | |
Nexperia BAT46WJ Single Schottky barrier diode 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition
Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
13.2 Definitions
malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of
Draft —
The document is a draft version only. The content is still under Nexperia products in such equipment or applications and internal review and subject to formal approval, which may result in therefore such inclusion and/or use is at the customer’s own risk. modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of
Applications —
Applications that are described herein for any of these information included herein and shall have no liability for the consequences of products are for illustrative purposes only. Nexperia makes no use of such information. representation or warranty that such applications will be suitable for the specified use without further testing or modification.
Short data sheet —
A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended Customers are responsible for the design and operation of their applications for quick reference only and should not be relied upon to contain detailed and and products using Nexperia products, and Nexperia full information. For detailed and full information see the relevant full data accepts no liability for any assistance with applications or customer product sheet, which is available on request via the local Nexperia sales design. It is customer’s sole responsibility to determine whether the Nexperia office. In case of any inconsistency or conflict with the short data sheet, the product is suitable and fit for the customer’s applications and full data sheet shall prevail. products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate
Product specification —
The information and data provided in a Product design and operating safeguards to minimize the risks associated with their data sheet shall define the specification of the product as agreed between applications and products. Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, Nexperia does not accept any liability related to any default, shall an agreement be valid in which the Nexperia product is damage, costs or problem which is based on any weakness or default in the deemed to offer functions and qualities beyond those described in the customer’s applications or products, or the application or use by customer’s Product data sheet. third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and
13.3 Disclaimers
the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect.
Limited warranty and liability —
Information in this document is believed to
Limiting values —
Stress above one or more limiting values (as defined in be accurate and reliable. However, Nexperia does not give any the Absolute Maximum Ratings System of IEC 60134) will cause permanent representations or warranties, expressed or implied, as to the accuracy or damage to the device. Limiting values are stress ratings only and (proper) completeness of such information and shall have no liability for the operation of the device at these or any other conditions above those given in consequences of use of such information. the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or In no event shall Nexperia be liable for any indirect, incidental, repeated exposure to limiting values will permanently and irreversibly affect punitive, special or consequential damages (including - without limitation - lost the quality and reliability of the device. profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such
Terms and conditions of commercial sale —
Nexperia damages are based on tort (including negligence), warranty, breach of products are sold subject to the general terms and conditions of commercial contract or any other legal theory. sale, as published at http://www.nexperia.com/profile/terms, unless otherwise Notwithstanding any damages that customer might incur for any reason agreed in a valid written individual agreement. In case an individual whatsoever, Nexperia’s aggregate and cumulative liability towards agreement is concluded only the terms and conditions of the respective customer for the products described herein shall be limited in accordance agreement shall apply. Nexperia hereby expressly objects to with the Terms and conditions of commercial sale of Nexperia. applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer.
Right to make changes —
Nexperia reserves the right to make changes to information published in this document, including without
No offer to sell or license —
Nothing in this document may be interpreted or limitation specifications and product descriptions, at any time and without construed as an offer to sell products that is open for acceptance or the grant, notice. This document supersedes and replaces all information supplied prior conveyance or implication of any license under any copyrights, patents or to the publication hereof. other industrial or intellectual property rights.
Suitability for use —
Nexperia products are not designed,
Export control —
This document as well as the item(s) described herein authorized or warranted to be suitable for use in life support, life-critical or may be subject to export control regulations. Export might require a prior safety-critical systems or equipment, nor in applications where failure or authorization from competent authorities. BAT46WJ All information provided in this document is subject to legal disclaimers. © Nexperia B.V. 2017. All rights reserved
Product data sheet Rev. 2 — 8 November 2011 10 of 12
Document Outline 1. Product profile 1.1 General description 1.2 Features and benefits 1.3 Applications 1.4 Quick reference data 2. Pinning information 3. Ordering information 4. Marking 5. Limiting values 6. Thermal characteristics 7. Characteristics 8. Test information 8.1 Quality information 9. Package outline 10. Packing information 11. Soldering 12. Revision history 13. Legal information 13.1 Data sheet status 13.2 Definitions 13.3 Disclaimers 13.4 Trademarks 14. Contact information 15. Contents
