Datasheet STD30PF03LT4, STD30PF03L-1 (STMicroelectronics) - 10
ПроизводительSTMicroelectronics
ОписаниеP-channel 30 V -0.025 Ω -24 A -DPAK / IPAK STripFET II Power MOSFET
Страниц / Страница13 / 10 — Package mechanical data. STD30PF03LT4 - STD30PF03L-1. TO-251 (IPAK) …
Формат / Размер файлаPDF / 337 Кб
Package mechanical data. STD30PF03LT4 - STD30PF03L-1. TO-251 (IPAK) MECHANICAL DATA. inch. DIM. MIN. TYP. MAX. 1 3
Package mechanical data STD30PF03LT4 - STD30PF03L-1 TO-251 (IPAK) MECHANICAL DATA inch DIM MIN TYP MAX 1 3
24 предложений от 16 поставщиков
MOSFET P-CH 30V 24A DPAK. P-Channel 30V 24A (Tc) 70W (Tc) Surface Mount DPAK. Transistors - FETs, MOSFETs - Single
STD30PF03LT4
STD30PF03L-T4
STD30PF03LT4
STD30PF03LT4
Package mechanical data STD30PF03LT4 - STD30PF03L-1 TO-251 (IPAK) MECHANICAL DATA mm inch DIM. MIN. TYP. MAX. MIN. TYP. MAX.
A 2.2 2.4 0.086 0.094 A1 0.9 1.1 0.035 0.043 A3 0.7 1.3 0.027 0.051 B 0.64 0.9 0.025 0.031 B2 5.2 5.4 0.204 0.212 B3 0.85 0.033 B5 0.3 0.012 B6 0.95 0.037 C 0.45 0.6 0.017 0.023 C2 0.48 0.6 0.019 0.023 D 6 6.2 0.236 0.244 E 6.4 6.6 0.252 0.260 G 4.4 4.6 0.173 0.181 H 15.9 16.3 0.626 0.641 L 9 9.4 0.354 0.370 L1 0.8 1.2 0.031 0.047 L2 0.8 1 0.031 0.039
H C A C2 A3 A1 D L L2 B3 B6 B B5 E B2 2 G
1 3 L1
0068771-E 10/13 Document Outline Figure 1. Internal schematic diagram Table 1. Device summary 1 Electrical ratings Table 2. Absolute maximum ratings Table 3. Thermal data 2 Electrical characteristics Table 4. On/off states Table 5. Dynamic Table 6. Switching times Table 7. Source drain diode 2.1 Electrical characteristics (curves) Figure 2. Safe operating area Figure 3. Thermal impedance Figure 4. Output characteristics Figure 5. Transfer characteristics Figure 6. Transconductance Figure 7. Static drain-source on resistance Figure 8. Gate charge vs gate-source voltage Figure 9. Capacitance variations Figure 10. Normalized gate threshold voltage vs temperature Figure 11. Normalized on resistance vs temperature Figure 12. Source-drain diode forward characteristics Figure 13. Normalized breakdown voltage vs temperature 3 Test circuit Figure 14. Switching times test circuit for resistive load Figure 15. Gate charge test circuit Figure 16. Test circuit for diode recovery behavior 4 Package mechanical data 5 Packaging mechanical data 6 Revision history Table 8. Document revision history
