Datasheet IMD111T-6F040, IMD112T-6F040 (Infineon) - 7
ПроизводительInfineon
ОписаниеSmart driver for motor control. Motor controller with integrated high-voltage gate driver
Страниц / Страница38 / 7 — iMOTION™ IMD111T/IMD112T - Smart driver for motor control. Motor …
Версия01_00
Формат / Размер файлаPDF / 761 Кб
iMOTION™ IMD111T/IMD112T - Smart driver for motor control. Motor controller with integrated high-voltage gate driver
iMOTION™ IMD111T/IMD112T - Smart driver for motor control Motor controller with integrated high-voltage gate driver
15 предложений от 7 поставщиков
Драйверы и Контроллеры
IMD112T6F040XUMA1
Infineon
226 ₽
IMD112T6F040XUMA1
Infineon
от 883 ₽
Hi-Tech Circuit Group
IMD112T6F040XUMA1
Infineon
IMD112T6F040XUMA1
Infineon
link to page 7
iMOTION™ IMD111T/IMD112T - Smart driver for motor control Motor controller with integrated high-voltage gate driver 2 Pin configuration Table 1 Pin definitions and functions (continued) Signal Type IMD111T IMD112T Description Motor control
COM P 9 9 Low side gate driver return LO1 O 12 12 Low side gate driver output - phase 1 LO2 O 11 11 Low side gate driver output - phase 2 LO3 O 10 10 Low side gate driver output - phase 3 VS1 P 19 19 High side gate driver return - phase 1 HO1 O 20 20 High side gate driver output - phase 1 VB1 P 21 21 High side gate driver positive power supply - phase 1 VS2 P 16 16 High side gate driver return - phase 2 HO2 O 17 17 High side gate driver output - phase 2 VB2 P 18 18 High side gate driver positive power supply - phase 2 VS3 P 13 13 High side gate driver return - phase 3 HO3 O 14 14 High side gate driver output - phase 3 VB3 P 15 15 High side gate driver positive power supply - phase 3 VDC AIN 36 36 DC bus sensing input ISS/IU AIN 40 40 Current sense input single shunt / phase U IV AIN 37 37 Current sense input phase V / analog input IW AIN 33 33 Current sense input phase W / analog input REFU
1)
O 39 39 Itrip single shunt/phase U reference DAC output REFV AIN 38 38 Itrip phase V reference / analog input REFW AIN 32 32 Itrip phase W reference / analog input
Hall sensor inputs
AHALL1+ AIN 32 32 Analog Hall Element input 1 (+) AHALL1- AIN 33 33 Analog Hall Element input 1 (-) AHALL2+ AIN 38 38 Analog Hall Element input 2 (+) AHALL2- AIN 37 37 Analog Hall Element input 2 (-) HALL1 I 28 28 Digital Hall sensor input 1 HALL2 I 29 29 Digital Hall sensor input 2 HALL3 I 30 30 Digital Hall sensor input 3
Power factor correction
PFCG0 O - 24 PFC gate drive 0 PFCG1 O - 25 PFC gate drive 1 (totem-pole PFC only) IPFC AIN - 34 PFC current sensing PFCREF AIN - 3 PFC Itrip comparator reference input PFCITRIP AIN - 4 PFC Itrip comparator input 1 This pin must have a filter capacitor connected to ground Datasheet 7 1.0 2020-12-4 Document Outline Features Potential applications Product validation Description Table of contents 1 Block diagram reference 2 Pin configuration 2.1 Pin definitions and functions 2.2 Pin configuration drawing IMD111T 2.3 Pin configuration drawing IMD112T 3 Functional description 3.1 Overview 3.2 Motion Control Engine 3.3 Gate Driver 3.4 Low Side Supply (VCC, VSS and COM) 3.5 High Side Supplies (VB1,2,3 and VS1,2,3) 3.6 Low and High Side Outputs (LO1,2,3 and HO1,2,3) 3.7 Internal Voltage Regulator 3.8 Application diagrams 4 Electrical characteristics and parameters 4.1 General parameters 4.1.1 Parameter Interpretation 4.1.2 Absolute maximum ratings 4.1.3 Pin Reliability in Overload 4.1.4 Operating Conditions 4.2 DC characteristics 4.2.1 Input/Output Characteristics 4.2.2 Analog to Digital Converter (ADC) 4.2.3 Analog comparator characteristics 4.2.4 Power Supply Current 4.2.5 Flash Memory Parameters 4.2.6 Static parameters gate driver 4.2.7 Static parameters voltage regulator 4.3 AC characteristics 4.3.1 Testing Waveforms 4.3.2 On-Chip Oscillator Characteristics 4.3.3 Dynamic parameters gate driver 4.3.4 Timing diagrams 4.4 Motor Control Parameters 4.4.1 PWM Characteristics 4.4.2 Current Sensing 4.4.3 Fault Timing 4.5 Power Factor Correction (PFC) parameters 4.5.1 Boost PFC characteristics 4.5.2 Totem Pole PFC characteristics 4.5.3 PFC Current Sensing 4.6 Control Interface Parameters 4.6.1 Control Input Interfaces 4.6.2 Serial Interface Parameters 4.6.2.1 UART Interface 4.6.3 Over Temperature Input 4.6.4 Pulse Output 5 Device and package specifications 5.1 Quality declaration 5.2 SBSL and Chip-IDs 5.3 Thermal considerations 5.4 Package Outline PG-LQFP-40-1 5.5 Part marking information Revision history Disclaimer
