Datasheet LT8606, LT8606B (Analog Devices) - 21
Описание42V, 350mA Synchronous Step-Down Regulator with 2.5µA Quiescent Current
Страниц / Страница24 / 21 — PACKAGE DESCRIPTION. MSE Package. 10-Lead Plastic MSOP, Exposed Die Pad. …
ВерсияD
Формат / Размер файлаPDF / 2.5 Мб
PACKAGE DESCRIPTION. MSE Package. 10-Lead Plastic MSOP, Exposed Die Pad. NO MEASUREMENT PURPOSE
PACKAGE DESCRIPTION MSE Package 10-Lead Plastic MSOP, Exposed Die Pad NO MEASUREMENT PURPOSE
31 предложений от 11 поставщиков
, Conv DC-DC 3V to 42V Synchronous Step Down Single-Out 0.778V to 41.4V 0.35A Micropower Automotive 10-Pin MSOP EP Tube
727GS
LT8606HMSE#PBF
от 214 ₽
Зенер
Россия и страны ТС
LT8606HMSE#PBF
от 413 ₽
LT8606HMSE#PBF
от 416 ₽
LT8606HMSE#TRPBF
Нулевые потери или высокая устойчивость: SiC Шоттки против традиционных быстрых диодов
LT8606/LT8606B
(Reference LTC DWG # 05-08-1664 Rev I) BOTTOM VIEW OF EXPOSED PAD OPTION 1.88 ±0.102 1.88 0.889 ±0.127 1 (.074 ±.004) (.074) 0.29 (.035 ±.005) 1.68 REF (.066) 5.10 0.05 REF (.201) 1.68 ±0.102 3.20 – 3.45 DETAIL “B” MIN (.066 ±.004) (.126 – .136) CORNER TAIL IS PART OF DETAIL “B” THE LEADFRAME FEATURE. 10 FOR REFERENCE ONLY 0.50
0.305 ± 0.038 (.0197) 3.00 ±0.102 (.0120 ±.0015) BSC (.118 ±.004) 0.497 ±0.076 TYP (NOTE 3) (.0196 ±.003) RECOMMENDED SOLDER PAD LAYOUT 10 9 8 7 6 REF 4.90 ±0.152 3.00 ±0.102 (.193 ±.006) (.118 ±.004) (NOTE 4) DETAIL “A” 0.254 (.010) 0° – 6° TYP 1 2 3 4 5 GAUGE PLANE 0.53 ±0.152 1.10 0.86 (.021 ±.006) (.043) (.034) MAX REF DETAIL “A” 0.18 (.007) SEATING PLANE 0.17 – 0.27 0.1016 ±0.0508 (.007 – .011) (.004 ±.002) TYP 0.50 MSOP (MSE) 0213 REV I (.0197) NOTE: BSC 1. DIMENSIONS IN MILLIMETER/(INCH) 2. DRAWING NOT TO SCALE 3. DIMENSION DOES NOT INCLUDE MOLD FLASH, PROTRUSIONS OR GATE BURRS. MOLD FLASH, PROTRUSIONS OR GATE BURRS SHALL NOT EXCEED 0.152mm (.006") PER SIDE 4. DIMENSION DOES NOT INCLUDE INTERLEAD FLASH OR PROTRUSIONS. INTERLEAD FLASH OR PROTRUSIONS SHALL NOT EXCEED 0.152mm (.006") PER SIDE 5. LEAD COPLANARITY (BOTTOM OF LEADS AFTER FORMING) SHALL BE 0.102mm (.004") MAX 6. EXPOSED PAD DIMENSION DOES INCLUDE MOLD FLASH. MOLD FLASH ON E-PAD SHALL NOT EXCEED 0.254mm (.010") PER SIDE. Rev. D For more information www.analog.com 21 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
