Datasheet ADA4098-1 (Analog Devices) - 6
Описание50 V, 1 MHz, 165 µA, Robust Over-The-Top Precision Op Amp
Страниц / Страница27 / 6 — ADA4098-1. Preliminary Technical Data. B Grade. H Grade. Parameter. Test …
ВерсияPrA
Формат / Размер файлаPDF / 1.6 Мб
ADA4098-1. Preliminary Technical Data. B Grade. H Grade. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
ADA4098-1 Preliminary Technical Data B Grade H Grade Parameter Test Conditions/Comments Min Typ Max Unit
23 предложений от 8 поставщиков
IC OPAMP GP 1 CIRCUIT TSOT6 / General Purpose Amplifier 1 Circuit Rail-to-Rail TSOT-6
Зенер
Россия и страны ТС
ADA4098-1HUJZ-RL7
от 362 ₽
ADA4098-1HUJZ-RL7
385 ₽
ADA4098-1HUJZ-RL7
от 508 ₽
727GS
ADA4098-1HUJZ-RL7
link to page 5 link to page 10 link to page 10 link to page 10
ADA4098-1 Preliminary Technical Data B Grade H Grade Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
SHDN PIN Input Logic Low Amplifier active, VSHDN < −VS + 0.5 V −VS + 0.5 −VS + 0.5 V Input Logic High Amplifier shutdown, VSHDN > −VS + 1.5 V −VS + 1.5 −VS + 1.5 V Response Time Amplifier active to shutdown 2.5 2.5 μs Amplifier shutdown to active 10 10 μs Pull-Down Current VSHDN = −VS + 0.5 V, TMIN < TA < TMAX 0.6 3 0.6 3 µA VSHDN = −VS + 1.5 V, TMIN < TA < TMAX 0.3 2.5 0.3 2.5 µA OUTPUT CHARACTERISTICS Output Voltage Swing Low V 3 OD = 30 mV, no load 45 60 45 60 mV TMIN < TA < TMAX 115 125 mV VOD = 30 mV, ISINK = 10 mA 260 360 260 360 mV TMIN < TA < TMAX 435 450 mV Output Voltage Swing High VOD = 30 mV, no load 45 55 45 55 mV TMIN < TA < TMAX 140 165 mV VOD = 30 mV, ISOURCE = 10 mA 900 1100 900 1100 mV TMIN < TA < TMAX 1500 1650 mV Short-Circuit Current ISOURCE 24 34 24 34 mA TMIN < TA < TMAX 15 12 mA ISINK 35 50 35 50 mA TMIN < TA < TMAX 20 20 mA Output Pin Leakage During VSHDN = −VS + 1.5 V ±5 ±5 nA Shutdown TMIN < TA < TMAX µA POWER SUPPLY Maximum Operating 50 50 V Voltage4 Operating Range Guaranteed by PSRR 3 50 3 50 V Supply Current Amplifier active 185 200 185 200 µA TMIN < TA < TMAX 272 285 µA VSY = ±25 V 195 210 195 210 µA TMIN < TA < TMAX 292 305 µA Amplifier shutdown, VSHDN = −VS + 1.5 V 17 24 17 24 µA TMIN < TA < TMAX 27 27 µA PSRR VSY = 3 V to 50 V 123 145 123 145 dB TMIN < TA < TMAX 120 120 dB THERMAL SHUTDOWN5 Temperature TJ 175 175 °C Hysteresis 20 20 °C Operating Temperature TA −40 +125 −55 +150 °C 1 Thermoelectric voltages present in the high speed production test limit the measurement accuracy of this parameter. The limits shown in Table 2 are determined by test capability and are not necessarily indicative of actual device performance. 2 Offset voltage drift is guaranteed through lab characterization and is not production tested. 3 VOD is +30 mV for VOUT high and −30 mV for VOUT low. 4 Maximum operating voltage is limited by the TDDB of on-chip capacitor oxides. The amplifier tolerates temporary transient overshoot up to the specified absolute maximum rating and the dc supply voltage must be limited to the maximum operating voltage. 5 Thermal shutdown is lab characterized only and is not tested in production. Rev. PrA | Page 6 of 27 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TYPICAL APPLICATION CIRCUIT TABLE OF CONTENTS SPECIFICATIONS 5 V SUPPLY ±15 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT PROTECTION OVER-THE-TOP OPERATION CONSIDERATIONS OUTPUT SHUTDOWN PIN (SHDN) APPLICATIONS INFORMATION LARGE RESISTOR GAIN OPERATION RECOMMENDED VALUES FOR VARIOUS GAINS NOISE DISTORTION POWER DISSIPATION AND THERMAL SHUTDOWN CIRCUIT LAYOUT CONSIDERATIONS POWER SUPPLY BYPASSING GROUNDING ESD PROTECTION WHEN POWERED RELATED PRODUCTS TYPICAL APPLICATIONS OUTLINE DIMENSIONS
