Datasheet AD746 (Analog Devices) - 3
ОписаниеDual Precision, 500 ns Settling, BiFET Op Amp
Страниц / Страница8 / 3 — AD746. boldface. ABSOLUTE MAXIMUM RATINGS1. METALIZATION PHOTOGRAPH. …
ВерсияB
Формат / Размер файлаPDF / 439 Кб
AD746. boldface. ABSOLUTE MAXIMUM RATINGS1. METALIZATION PHOTOGRAPH. CAUTION. WARNING!. ESD SENSITIVE DEVICE
AD746 boldface ABSOLUTE MAXIMUM RATINGS1 METALIZATION PHOTOGRAPH CAUTION WARNING! ESD SENSITIVE DEVICE
13 предложений от 12 поставщиков
Микросхема Операционный усилитель, Precision Amplifiers DUAL PREC BIFET 13MHz 18V
AD746SQ/883B
13 810 ₽
Эиком
AD746SQ/883B
15 665 ₽
TradeElectronics
AD746SQ/883B
AD746SQ/883B
AD746
NOTES 1Input Offset Voltage specifications are guaranteed after 5 minutes of operation at T A = +25°C. 2PSRR test conditions: +VS = 15 V, –VS = –12 V to –18 V and +VS = 12 V to 18 V, –VS = –15 V. 3Bias Current Specifications are guaranteed maximum at either input after 5 minutes of operation at T A = +25°C. For higher temperature, the current doubles every 10°C. 4Gain = –1, Rl = 2 k, Cl = 10 pF. 5Defined as voltage between inputs, such that neither exceeds ±10 V from ground. 6Typically exceeding –14.1 V negative common-mode voltage on either input results in an output phase reversal. Specifications subject to change without notice. Specifications in
boldface
are tested on all production units at final electrical test. Results from those tests are used to calculate outgoing quality levels. All min and max specifications are guaranteed, although only those shown in
boldface
are tested on all production units.
Lead Temperature Range Supply Voltage . .± 18 V (Soldering 60 seconds) . +300°C Internal Power Dissipation2 . 500 mW ESD Rating . Input Voltage . ± V NOTES S 1 Output Short Circuit Duration Stresses above those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional (For One Amplifier) . Indefinite operation of the device at these or any other conditions above those indicated in Differential Input Voltage . +VS and –VS the operational section of this specification is not implied. Exposure to absolute Storage Temperature Range (Q) . –65°C to +150°C maximum rating conditions for extended periods may affect device reliability. Storage Temperature Range (N, R) . –65°C to +125°C 28-Pin Plastic Package: θJA = 100°C/Watt, θJC = 50°C/Watt Operating Temperature Range 8-Pin Cerdip Package: θJA = 110°C/Watt, θJC = 30°C/Watt 8-Pin Small Outline Package: θ AD746J . 0°C to +70°C JA = 160°C/Watt, θJC = 42°C/Watt AD746A/B . –40°C to +85°C AD746S . –55°C to +125°C
Contact factory for latest dimensions. Dimensions shown in inches and (mm).
CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection.
WARNING!
Although the AD746 features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD
precautions are recommended to avoid performance degradation or loss of functionality. REV. B –3–
