Datasheet AD843 (Analog Devices) - 2
Описание34 MHz, CBFET Fast Settling Op Amp
Страниц / Страница12 / 2 — AD843–SPECIFICATIONS (@ TA = +25. C and. 15 V dc, unless otherwise …
ВерсияD
Формат / Размер файлаPDF / 466 Кб
AD843–SPECIFICATIONS (@ TA = +25. C and. 15 V dc, unless otherwise noted). AD843J/A. AD843K/B. AD843S1. Model. Conditions. Min. Typ. Max
AD843–SPECIFICATIONS (@ TA = +25 C and 15 V dc, unless otherwise noted) AD843J/A AD843K/B AD843S1 Model Conditions Min Typ Max
17 предложений от 16 поставщиков
IC OPAMP GP 34MHZ 50MA 8CERDIP. Amplifier Circuit. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps
727GS
AD843SQ/883B
от 412 ₽
AD843SQ/883B
5 606 ₽
AD843SQ/883B
AD843SQ/883B
C and
15 V dc, unless otherwise noted) AD843J/A AD843K/B AD843S1 Model Conditions Min Typ Max Min Typ Max Min Typ Max Units
INPUT OFFSET VOLTAGE1 1.0
2.0
0.5
1.0
1.0
2.0
mV TMIN-TMAX 1.7 4.0 1.2
2.0
3.0
4.5
mV Offset Drift 12 12 35 12 µV/°C INPUT BIAS CURRENT Initial (TJ = +25°C) 50 40 50 pA Warmed-Up2 0.8
2.5
0.6
1.0
0.8
2.5
nA TMIN-TMAX 60/160 23/65 2600 nA INPUT OFFSET CURRENT Initial (TJ = +25°C) 30 20 30 pA Warmed-Up2 0.25
1.0
0.2
0.4
0.25
1.0
nA TMIN-TMAX 23/64 9/26 1025 nA INPUT CHARACTERISTICS Input Resistance 1010 1010 1010 Ω Input Capacitance 6 6 6 pF INPUT VOLTAGE RANGE Common Mode 6
10
+12, 6
10
+12, 6
10
+12, V –13 –13 –13 COMMON-MODE REJECTION VCM = ± 10 V
60
72
70
76
60
72 dB TMIN-TMAX 60 72
68
76
60
72 dB INPUT VOLTAGE NOISE f = 10 kHz 19 19 19 nV/√Hz Wideband Noise 10 Hz to 10 MHz 60 60 60 µV rms OPEN LOOP GAIN VO = ± 10 V RLOAD ≥ 500 Ω
15
25
20
30
15
30 V/mV TMIN-TMAX 10 20
10
25
10
25 V/mV OUTPUT CHARACTERISTICS Voltage RLOAD ≥ 500 Ω 6
10
+11.5, 6
10
+11.5, 6
10
+11.5, V –12.6 –12.6 –12.6 Current VOUT = ± 10 V
50 50 50
mA Output Resistance Open Loop 12 12 12 Ω FREQUENCY RESPONSE Unity Gain Bandwidth VOUT = 90 mV p-p 34 34 34 MHz Full Power Bandwidth3 VO = 20 V p-p R1 ≥ 500 Ω 2.5 3.9 2.5 3.9 2.5 3.9 MHz Rise Time AVCL = –1 10 10 10 ns Overshoot AVCL = –1 15 15 15 % Slew Rate AVCL = –1 160 250 160 250 160 250 V/µs Settling Time 10 V Step AVCL = –1 to 0.1% 95 95 95 ns to 0.01% 135 135 135 ns Overdrive Recovery –Overdrive 200 200 200 ns +Overdrive 700 700 700 ns Differential Gain f = 4.4 MHz 0.025 0.025 0.025 % Differential Phase f = 4.4 MHz 0.025 0.025 0.025 Degree POWER SUPPLY Rated Performance ±15 ±15 ±15 V Operating Range 6
4.5
6
18
6
4.5
6
18
6
4.5
6
18
V Quiescent Current 12
13
12
13
12
13
mA TMIN-TMAX 12.3 14 12.3
14
12.5
16
mA Rejection Ratio ±5 V to ±18 V
65
76
70
80
65
76 dB Rejection Ratio TMIN-TMAX 62 76
68
80
62
76 dB TEMPERATURE RANGE Operating, Rated Performance Commercial (0°C to +70°C) AD843J AD843K Industrial (– 40°C to +85°C) AD843A AD843B Military (–55°C to +125°C)4 AD843S PACKAGE OPTIONS Plastic (N-8) AD843JN AD843KN Cerdip (Q-8) AD843AQ AD843BQ AD843SQ, AD843SQ/883B Metal Can (H-12A) AD843BH AD843SH, AD843SH/883B LCC (E-20A) AD843SE/883B SOIC (R-16) AD843JR–16 Tape & Reel AD843JR-16–REEL AD843JR-16–REEL7 Chips AD843JCHIPS AD843SCHIPS –2– REV. D
