Datasheet OP400 (Analog Devices) - 2
ОписаниеQuad Low-Offset, Low-Power Operational Amplifier
Страниц / Страница5 / 2 — OP400. 3.3. Absolute Maximum Ratings. 4.0. Die Qualification. Table I - …
ВерсияH 09/2014
Формат / Размер файлаPDF / 347 Кб
OP400. 3.3. Absolute Maximum Ratings. 4.0. Die Qualification. Table I - Dice Electrical Characteristics
OP400 3.3 Absolute Maximum Ratings 4.0 Die Qualification Table I - Dice Electrical Characteristics
5962L8777102VKA
1/ Supply Voltage (VCC).. ±20V Differential Input Voltage.. ±30V Input Voltage... Supply Voltage Output Short-Circuit Duration...Continuous Storage Temperature Range ... -65°C to +150°C Junction Temperature (TJ)………………………………..+150°C Operating Temperature Range...-55°C to +125°C Absolute Maximum Ratings Notes: 1/ Stresses above the absolute maximum rating may cause permanent damage to the device. Extended operation at the maximum levels may degrade performance and affect reliability.
Conditions Limit Limit Parameter Symbol Units 1/ Min Max Input Offset Voltage V IO -150 +150 µV Input Offset Current IIO VCM = 0V -1 +1 nA Input Bias Current ±IIB VCM = 0V -3 +3 nA Input Voltage Range IVR ±12 V Common Mode Rejection CMRR V dB Ratio CM = IVR 120 Power Supply Rejection PSRR V 1.8 µV/V Ratio S = ±3V to ±18V Supply Current 2/ ISY No Load 2.9 mA Large Signal Voltage Gain AVS VOUT = ±10V, RL = 2kΩ 1500 V/mV Output Voltage Swing V = OP RL 2kΩ ±11 V Table I Notes: 1/ VS = ±15V, TA = 25°C, unless otherwise specified. 2/ ISY limit = total all four amplifiers.
