Линейка продуктов KEEN SIDE
Datasheet HMC1082CHIP (Analog Devices) - 4
Описание5.5 GHz to 18 GHz, GaAs, pHEMT, MMIC, Medium Power Amplifier
Страниц / Страница15 / 4 — HMC1082CHIP. Data Sheet. 15.5 GHz TO 18 GHz FREQUENCY RANGE. Table 3. …
ВерсияB
Формат / Размер файлаPDF / 378 Кб
HMC1082CHIP. Data Sheet. 15.5 GHz TO 18 GHz FREQUENCY RANGE. Table 3. Parameter. Symbol. Min. Typ. Max. Unit. Test Conditions/Comments
HMC1082CHIP Data Sheet 15.5 GHz TO 18 GHz FREQUENCY RANGE Table 3 Parameter Symbol Min Typ Max Unit Test Conditions/Comments
HMC1082CHIP
TA = 25°C, VDD = 5 V, and IDQ = 220 mA, unless otherwise noted.
Table 3. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 15.5 18 GHz GAIN 23 25 dB Gain Variation Over Temperature 0.009 dB/°C RETURN LOSS Input 14.5 dB Output 20 dB OUTPUT Output Power for 1 dB Compression P1dB 22 24 dBm Saturated Output Power PSAT 24.5 dBm Output Third-Order Intercept IP3 35.5 dBm Measurement taken at POUT per tone = 12 dBm SUPPLY Current IDQ 220 mA Adjust VGG to achieve IDQ = 220 mA typical Voltage VDD 4 5 V Rev. B | Page 4 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 5.5 GHz TO 7 GHz FREQUENCY RANGE 7 GHz TO 15.5 GHz FREQUENCY RANGE 15.5 GHz TO 18 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION RECOMMENDED BIAS SEQUENCING MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
