Datasheet HMC789ST89E (Analog Devices) - 8
ОписаниеInGaP HBT GAIN BLOCK MMIC AMPLIFIER, 0.7 -2.8 GHz
Страниц / Страница16 / 8 — HMC789ST89E. InGaP HBT GAIN BLOCK MMIC. AMPLIFIER, 0.7 -2.8 GHz. Reverse …
Формат / Размер файлаPDF / 716 Кб
HMC789ST89E. InGaP HBT GAIN BLOCK MMIC. AMPLIFIER, 0.7 -2.8 GHz. Reverse Isolation vs. Noise Figure vs. Temperature @ 2600 MHz
HMC789ST89E InGaP HBT GAIN BLOCK MMIC AMPLIFIER, 0.7 -2.8 GHz Reverse Isolation vs Noise Figure vs Temperature @ 2600 MHz
23 предложений от 16 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
727GS
HMC789ST89E
144 ₽
HMC789ST89E
Hittite
693 ₽
ЧипСити
HMC789ST89E
807 ₽
HMC789ST89E
1 810 ₽
HMC789ST89E
v02.0314
InGaP HBT GAIN BLOCK MMIC AMPLIFIER, 0.7 -2.8 GHz Reverse Isolation vs. Noise Figure vs. Temperature @ 2600 MHz Temperature @ 2600 MHz
8 -10 +25 C T 6 +85 C - 40 C ) +25 C -15 +85 C M ) (dB - 40 C N (dB 4 IO F T N LA O IS -20 K - S 2 C LO 0 -25 2.3 2.4 2.5 2.6 2.7 2.8 2.3 2.4 2.5 2.6 2.7 2.8 FREQUENCY (GHz) FREQUENCY (GHz) IN B A
Gain, Power & IP3 vs. Supply Voltage @ 2600 MHz Power Compression @ 2600 MHz
50 40 ) m R & G (%) Pout E 3 (dB 40 IP 30 Gain PAE PAE IV ), O m Gain B (dB), R P1dB (d 30 OIP3 20 GAIN P1dB 20 (dB), (dBm), 10 S - D Pout GAIN R 10 0 IE 4.5 5 5.5 0 5 10 15 20 SUPPLY VOLTAGE INPUT POWER (dBm) LIF P M A I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
8
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
