Datasheet ADL5320 (Analog Devices) - 4
Описание400 MHz TO 2700 MHz ¼ Watt RF Driver Amplifier
Страниц / Страница20 / 4 — ADL5320. Data Sheet. TYPICAL SCATTERING PARAMETERS. Table 2. S11. S21. …
ВерсияB
Формат / Размер файлаPDF / 919 Кб
ADL5320. Data Sheet. TYPICAL SCATTERING PARAMETERS. Table 2. S11. S21. S12. S22. Freq (MHz)
ADL5320 Data Sheet TYPICAL SCATTERING PARAMETERS Table 2 S11 S21 S12 S22 Freq (MHz)
27 предложений от 13 поставщиков
Усилитель IC и модуль RF, ANALOG DEVICES ADL5320ARKZ-R7 RF Amplifier IC, 16.9dB Gain, 400MHz to 2.7GHz, 3.3V to 5.5V, 520mW, SOT-89-3...
Зенер
Россия и страны ТС
ADL5320ARKZ-R7
от 904 ₽
ADL5320ARKZ-R7
от 980 ₽
ADL5320ARKZ-R7
727GS
ADL5320ARKZ-R7
VSUP = 5 V and TA = 25°C; the effects of the test fixture have been de-embedded up to the pins of the device.
Table 2. S11 S21 S12 S22 Freq (MHz) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°)
400 −1.42 −179.88 +14.16 +134.74 −32.56 +13.47 −3.42 +176.22 500 −1.38 +175.04 +13.97 +126.21 −32.02 +8.58 −3.71 +175.38 550 −1.42 +173.05 +13.81 +122.24 −31.84 +6.81 −3.84 +175.10 600 −1.48 +171.25 +13.66 +118.41 −31.70 +5.25 −3.96 +174.89 650 −1.54 +169.59 +13.49 +114.71 −31.56 +3.85 −4.08 +174.74 700 −1.62 +168.11 +13.32 +111.12 −31.43 +2.63 −4.19 +174.71 750 −1.70 +166.66 +13.17 +107.64 −31.29 +1.35 −4.30 +174.74 800 −1.80 +165.36 +13.05 +104.27 −31.16 +0.20 −4.41 +174.89 850 −1.90 +163.99 +12.94 +100.86 −31.01 −0.95 −4.52 +175.10 900 −2.01 +162.65 +12.84 +97.48 −30.85 −2.23 −4.62 +175.37 950 −2.13 +161.32 +12.73 +94.09 −30.69 −3.43 −4.71 +175.78 1000 −2.27 +159.98 +12.65 +90.72 −30.52 −4.80 −4.81 +176.29 1050 −2.43 +158.61 +12.62 +87.34 −30.32 −6.24 −4.89 +176.85 1100 −2.63 +157.11 +12.59 +83.90 −30.15 −7.92 −4.98 +177.52 1150 −2.84 +155.60 +12.56 +80.41 −29.95 −9.61 −5.06 +178.29 1200 −3.09 +153.91 +12.55 +76.75 −29.74 −11.56 −5.12 +179.17 1250 −3.39 +152.08 +12.56 +73.03 −29.54 −13.63 −5.18 −179.85 1300 −3.73 +150.14 +12.57 +69.24 −29.33 −15.87 −5.25 −178.72 1350 −4.13 +147.98 +12.61 +65.23 −29.12 −18.39 −5.28 −177.52 1400 −4.59 +145.57 +12.66 +61.05 −28.91 −21.17 −5.29 −176.26 1450 −5.13 +143.05 +12.72 +56.75 −28.69 −24.17 −5.27 −174.93 1500 −5.76 +140.31 +12.79 +52.20 −28.48 −27.48 −5.19 −173.52 1550 −6.48 +137.18 +12.83 +47.46 −28.28 −31.05 −5.12 −172.60 1600 −7.36 +133.46 +12.89 +42.49 −28.10 −34.99 −5.06 −171.45 1650 −8.45 +129.65 +12.93 +37.41 −27.95 −39.05 −4.94 −170.38 1700 −9.74 +125.36 +12.98 +32.12 −27.81 -43.45 −4.80 −169.52 1750 −11.32 +120.71 +12.99 +26.74 −27.70 −48.12 −4.65 −168.95 1800 −13.34 +115.47 +12.99 +21.16 −27.61 −53.06 −4.47 −168.68 1850 −16.00 +109.24 +12.97 +15.43 −27.56 −58.23 -4.30 −168.76 1900 −19.89 +100.84 +12.93 +9.57 −27.55 −63.67 −4.14 −169.26 1950 −26.68 +83.39 +12.86 +3.65 −27.58 −69.38 −3.99 −170.11 2000 −33.34 −26.40 +12.76 −2.46 −27.65 −75.33 −3.86 −171.37 2050 −23.21 −71.32 +12.64 −8.60 −27.75 −81.44 −3.74 −172.97 2100 −18.39 −83.50 +12.49 −14.83 −27.89 −87.92 −3.65 −175.01 2150 −15.39 −92.08 +12.31 −21.09 −28.07 −94.55 −3.58 −177.37 2200 −13.26 −100.04 +12.11 −27.46 −28.29 −101.56 −3.54 +179.90 2250 −11.63 −107.86 +11.88 −33.90 −28.54 −108.80 −3.50 +176.83 2300 −10.31 −115.84 +11.62 −40.49 −28.82 −116.46 −3.47 +173.43 2350 −9.20 −123.94 +11.33 −47.09 −29.15 −124.41 −3.44 +169.75 2400 −8.23 −132.24 +11.01 −53.81 −29.50 −132.81 −3.42 +165.83 2450 −7.38 −140.88 +10.64 −60.65 −29.89 −141.70 −3.40 +161.63 2500 −6.61 −149.66 +10.24 −67.57 −30.31 −150.89 −3.36 +157.29 2550 −5.89 −158.59 +9.78 −74.53 −30.76 −160.57 −3.31 +152.82 2600 −5.23 −167.51 +9.27 −81.60 −31.23 −170.68 −3.24 +148.32 2650 −4.62 −176.26 +8.70 −88.50 −31.73 +178.90 −3.17 +143.81 2700 −4.05 +175.18 +8.07 −95.43 −32.22 +168.34 −3.09 +139.40 Rev. B | Page 4 of 20 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics High Temperature and 3.3 V Operation Applications Information Basic Layout Connections Soldering Information and Recommended PCB Land Pattern Matching Procedure Optimizing OP1dB W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
