Datasheet HMC594LC3B (Analog Devices) - 4
ОписаниеGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 2 - 4 GHz
Страниц / Страница6 / 4 — HMC594LC3B. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 2 - 4 GHz. Absolute …
Формат / Размер файлаPDF / 366 Кб
HMC594LC3B. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 2 - 4 GHz. Absolute Maximum Ratings. Typical Supply Current vs. Vdd
HMC594LC3B GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 2 - 4 GHz Absolute Maximum Ratings Typical Supply Current vs Vdd
7 предложений от 7 поставщиков
Усилитель IC и модуль RF, Ic Mmicpwr Amp Lna Gaas 12smd
HMC594LC3BTR-R5
Hittite
2 874 ₽
HMC594LC3BTR-R5
3 060 ₽
HMC594LC3BTR-R5
HMC594LC3BTR-R5
HMC594LC3B
v03.0514
GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 2 - 4 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd
Drain Bias Voltage (Vdd) 7V Vdd (V) Idd (mA) RF Input Power (RFIN)(Vdd = +6V) +15 dBm +5.5 97 T Channel Temperature 175 °C +6.0 100 M Continuous Pdiss (T = 85 °C) +6.5 103 0.9 W (derate 10 mW/°C above 85 °C) Note: Amplifier will operate over full voltage range shown above Thermal Resistance 100 °C/W (channel to ground paddle) E - S Storage Temperature -65 to +150 °C IS Operating Temperature -40 to +85 °C ELECTROSTATIC SENSITIVE DEVICE O OBSERVE HANDLING PRECAUTIONS W N O
Outline Drawing
S - L R IE LIF P M A NOTES: 1. PACKAGE BODY MATERIAL: ALUMINA 2. LEAD AND GROUND PADDLE PLATING: GOLD FLASH OVER Ni. 3. DIMENSIONS ARE IN INCHES [MILLIMETERS]. 4. LEAD SPACING TOLERANCE IS NON-CUMULATIVE 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm. 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND.
Package Information
Part Number Package Body Material Lead Finish MSL Rating Package Marking [2] HMC594LC3B Alumina, White Gold over Nickel MSL3 [1] H594 XXXX [1] Max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
