Datasheet ADL8111 (Analog Devices) - 5
Описание10 MHz to 8000 MHz Bypass Amplifier
Страниц / Страница24 / 5 — Data Sheet. ADL8111. ABSOLUTE MAXIMUM RATINGS Table 5. POWER DERATING …
Формат / Размер файлаPDF / 811 Кб
Data Sheet. ADL8111. ABSOLUTE MAXIMUM RATINGS Table 5. POWER DERATING CURVES. Parameter. Rating. B) d (. ING. RAT. –10. R DE E W. –15. O P. –20
Data Sheet ADL8111 ABSOLUTE MAXIMUM RATINGS Table 5 POWER DERATING CURVES Parameter Rating B) d ( ING RAT –10 R DE E W –15 O P –20
5 предложений от 5 поставщиков
, RF Amp Single LNA 8GHz ±3.6V/5.5V 28-Pin LGA EP T/R
ADL8111ACCZN-R7
3 944 ₽
ADL8111ACCZN-R7
5 135 ₽
ADL8111ACCZN-R7
10 071 ₽
Microfind
ADL8111ACCZN-R7
10 855 ₽
link to page 24
Data Sheet ADL8111 ABSOLUTE MAXIMUM RATINGS Table 5. POWER DERATING CURVES Parameter Rating 5
VDD_PA +7 V dc VDD_SW Range −0.3 V to +3.7 V
0
VSS_SW Range −3.7 V to +0.3 V
B) d ( –5
Control Voltage (VA, VB) Range −0.3 V to VDD + 0.3 V
ING RAT –10
RF Input Power (RFIN) − Internal Amplifier State 20 dBm RFIN − Internal Bypass, 31 dBm
R DE E W –15
External Bypass A, External Bypass B
O P
RFIN (IN_A, OUT_A, IN_B, and OUT_B) 28 dBm
–20
Termination Path (VDD_SW, VA, VB = 3.3 V, VSS = −3.3 V, TA = 85°C, and Frequency = 2 GHz)
–25 0.01 0.1 1 10 100 1k 10k
002 Hot Switch Power Level (IN_A, OUT_A, IN_B, 30 dBm
FREQUENCY (MHz)
20106- and OUT_B), VDD_SW = 3.3 V, TA = 85°C, Figure 2. Power Derating for RFIN Port and Frequency = 2 GHz
2
Hot Switch Power Level (Internal Amplifier 20 dBm State)
0
Continuous Power Dissipation, P
–2
DISS 0.61 W (TA = 85°C, Derate 6.8 mW/°C Above 85°C)
B) –4 d (
Channel Temperature 175°C
–6 ING
Maximum Peak Reflow Temperature 260°C
RAT –8
(Moisture Sensitivity Level 3, MSL3)1
R DE
Storage Temperature Range −40°C to +125°C
–10 E W
Operating Temperature Range −40°C to +85°C
O –12 P
ESD Sensitivity (Human Body Model) Class 1B
–14
(Passed ±750 V)
–16
1 See the Ordering Guide section for additional information.
–18 10k 100k 1M 10M 100M 1G 10G
003 Stresses at or above those listed under Absolute Maximum
FREQUENCY (Hz)
20106- Ratings may cause permanent damage to the product. This is a Figure 3. Power Derating for Terminated Path stress rating only; functional operation of the product at these
2
or any other conditions above those indicated in the operational
0
section of this specification is not implied. Operation beyond
–2
the maximum operating conditions for extended periods may
B) –4
affect product reliability.
d ( –6 ING THERMAL RESISTANCE RAT –8
Thermal performance is directly linked to the printed circuit
R DE –10 E
board (PCB) design and operating environment. Careful
W O –12
attention to PCB thermal design is required.
P –14
θJC is the junction to case thermal resistance.
–16 Table 6. Thermal Resistance –18 10k 100k 1M 10M 100M 1G 10G
004
Package Type θJC Unit FREQUENCY (Hz)
20106- CC-28-31 148 °C/W Figure 4. Power Derating for Hot Switching Power 1 θ
ESD CAUTION
JC was determined by simulation under the following conditions: the heat transfer is due solely to thermal conduction from the channel through the ground paddle to the PCB, and the ground paddle is held constant at an 85°C operating temperature. Rev. 0 | Page 5 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE POWER DERATING CURVES ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS EXTERNAL BYPASS A STATE INTERNAL AMPLIFIER STATE INTERNAL BYPASS STATE EXTERNAL BYPASS B STATE TEST CIRCUITS THEORY OF OPERATION SIGNAL PATH STATES FOR DIGITAL CONTROL INPUTS APPLICATIONS INFORMATION RECOMMENDED BIAS SEQUENCING During Power-Up During Power-Down EVALUATION PCB EVALUATION BOARD SCHEMATIC OUTLINE DIMENSIONS ORDERING GUIDE
