Оптопары и оптореле Megawin
Datasheet HMC8412 (Analog Devices) - 3
ОписаниеLow Noise Amplifier, 0.4 GHz to 11 GHz
Страниц / Страница18 / 3 — Data Sheet. HMC8412. SPECIFICATIONS 0.4 GHz TO 3 GHz FREQUENCY RANGE. …
Формат / Размер файлаPDF / 434 Кб
Data Sheet. HMC8412. SPECIFICATIONS 0.4 GHz TO 3 GHz FREQUENCY RANGE. Table 1. Parameter. Min Typ. Max Unit
Data Sheet HMC8412 SPECIFICATIONS 0.4 GHz TO 3 GHz FREQUENCY RANGE Table 1 Parameter Min Typ Max Unit
21 предложений от 10 поставщиков
RF Amp Single LNA 11GHz 6V 6-Pin LFCSP EP T/R
HMC8412LP2FETR
4 883 ₽
Зенер
Россия и страны ТС
HMC8412LP2FETR
от 5 325 ₽
Эиком
HMC8412LP2FETR
от 10 950 ₽
HMC8412LP2FETR
VDD = 5 V, supply current (IDQ) = 60 mA, RBIAS = 1.47 kΩ, and TA = 25°C, unless otherwise noted.
Table 1. Parameter Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 0.4 3 GHz GAIN 13 15.5 dB Gain Variation over Temperature 0.010 dB/°C NOISE FIGURE 1.4 dB RETURN LOSS Input 14 dB Output 13 dB OUTPUT Power for 1 dB Compression (OP1dB) 15 18 dBm PSAT 20.5 dBm OIP3 32 dBm Measurement taken at output power (POUT) per tone = 0 dBm Second-Order Intercept (OIP2) 40 dBm Measurement taken at POUT per tone = 0 dBm POWER ADDED EFFICIENCY (PAE) 28 % Measured at PSAT SUPPLY IDQ 60 mA VDD 2 5 6 V
3 GHz TO 9 GHz FREQUENCY RANGE
VDD = 5 V, IDQ = 60 mA, RBIAS = 1.47 kΩ, and TA = 25°C, unless otherwise noted.
Table 2. Parameter Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 3 9 GHz GAIN 13 15 dB Gain Variation over Temperature 0.012 dB/°C NOISE FIGURE 1.5 dB RETURN LOSS Input 15 dB Output 16 dB OUTPUT OP1dB 15.5 18 dBm PSAT 20.5 dBm OIP3 33 dBm Measurement taken at POUT per tone = 0 dBm OIP2 41.5 dBm Measurement taken at POUT per tone = 0 dBm PAE 29 % Measured at PSAT SUPPLY IDQ 60 mA VDD 2 5 6 V Rev. 0 | Page 3 of 18 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications 0.4 GHz to 3 GHz Frequency Range 3 GHz to 9 GHz Frequency Range 9 GHz to 11 GHz Frequency Range Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for HMC8412 ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Recommended Bias Sequencing Power-Up Sequence Power-Down Sequence Outline Dimensions Ordering Guide
