Линейка продуктов KEEN SIDE
Datasheet HMC392A (Analog Devices) - 6
ОписаниеGaAs MMIC LOW NOISE AMPLIFIER, 3.5 - 7.0 GHz
Страниц / Страница6 / 6 — HMC392A. GaAs MMIC LOW NOISE. AMPLIFIER, 3.5 - 7.0 GHz. Assembly Diagram. …
Формат / Размер файлаPDF / 530 Кб
HMC392A. GaAs MMIC LOW NOISE. AMPLIFIER, 3.5 - 7.0 GHz. Assembly Diagram. Handling Precautions. Storage:. Cleanliness:
HMC392A GaAs MMIC LOW NOISE AMPLIFIER, 3.5 - 7.0 GHz Assembly Diagram Handling Precautions Storage: Cleanliness:
7 предложений от 7 поставщиков
, RF Amp Single LNA 7GHz 7V 10Pin Die Tray
HMC392A
4 991 ₽
ЧипСити
HMC392A
6 347 ₽
Элитан
HMC392A-SX
24 575 ₽
HMC392A
HMC392A
v02.0618
IP H E - C IS O W N O R - L IE LIF P M A Note: State 2 shown. PS2 bonded to ground.
Follow these precautions to avoid permanent damage.
Storage:
All bare die are placed in either Waffle or Gel based ESD protective containers, and then sealed in an ESD protective bag for shipment. Once the sealed ESD protective bag has been opened, all die should be stored in a dry nitrogen environment.
Cleanliness:
Handle the chips in a clean environment. DO NOT attempt to clean the chip using liquid cleaning systems.
Static Sensitivity:
Follow ESD precautions to protect against ESD strikes.
Transients:
Suppress instrument and bias supply transients while bias is applied. Use shielded signal and bias cables to minimize inductive pick-up.
General Handling:
Handle the chip along the edges with a vacuum collet or with a sharp pair of bent tweezers. The surface of the chip has fragile air bridges and should not be touched with vacuum collet, tweezers, or fingers.
Mounting
The chip is back-metallized and can be die mounted with AuSn eutectic preforms or with electrically conductive epoxy. The mounting surface should be clean and flat.
Eutectic Die Attach:
A 80/20 gold tin preform is recommended with a work surface temperature of 255 °C and a tool temperature of 265 °C. When hot 90/10 nitrogen/hydrogen gas is applied, tool tip temperature should be 290 °C. DO NOT expose the chip to a tem- perature greater than 320 °C for more than 20 seconds. No more than 3 seconds of scrubbing should be required for attachment.
Epoxy Die Attach:
Apply a minimum amount of epoxy to the mounting surface so that a thin epoxy fillet is observed around the perimeter of the chip once it is placed into position. Cure epoxy per the manufacturer’s schedule.
Wire Bonding
Ball or wedge bond with 0.025mm (1 mil) diameter pure gold wire. Thermosonic wirebonding with a nominal stage temperature of 150 °C and a ball bonding force of 40 to 50 grams or wedge bonding force of 18 to 22 grams is recommended. Use the minimum level of ultrasonic energy to achieve reliable wirebonds. Wirebonds should be started on the chip and terminated on the package or substrate. All bonds should be as short as possible <0.31mm (12 mils). For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
6
Application Support: Phone: 1-800-ANALOG-D
