Datasheet HMC717ALP3E (Analog Devices) - 3
ОписаниеGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 4.8 - 6.0 GHz
Страниц / Страница11 / 3 — HMC717ALP3E. Gaas pHEMT MMIC LOW NOIsE. aMpLIFIER, 4.8 - 6.0 GHz. Noise …
HMC717ALP3E. Gaas pHEMT MMIC LOW NOIsE. aMpLIFIER, 4.8 - 6.0 GHz. Noise Figure vs. Temperature [1] [2]
HMC717ALP3E Gaas pHEMT MMIC LOW NOIsE aMpLIFIER, 4.8 - 6.0 GHz Noise Figure vs Temperature [1] [2]
24 предложений от 12 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
Microfind
HMC717ALP3ETR
275 ₽
ЧипСити
HMC717ALP3ETR
289 ₽
Рутоника
HMC717ALP3ETR
637 ₽
Зенер
Россия и страны ТС
HMC717ALP3ETR
от 880 ₽
HMC717ALP3E
v09.0816
Gaas pHEMT MMIC LOW NOIsE aMpLIFIER, 4.8 - 6.0 GHz Noise Figure vs. Temperature [1] [2] p1dB vs. Temperature [1] [2]
2.1 24 T +85C Vdd=5V 22 1.8 M ) 20 B 1.5 d ( ) E 18 m R 1.2 U (dB 16 IG F 0.9 E - S E 1dB P 14 IS O N 0.6 IS 12 -40C 0.3 +25C O 10 Vdd=3V 0 8 4.4 4.6 4.8 5 5.2 5.4 5.6 5.8 6 4.5 4.8 5.1 5.4 5.7 6 FREQUENCY (GHz) FREQUENCY (GHz) W N +25C +85C -40C Vdd=5V Vdd=3V O
psat vs. Temperature [1] [2] Output Ip3 vs. Temperature [1] [2]
R - L 24 40 IE Vdd=5V Vdd=5V 22 37 20 34 LIF ) 18 ) 31 P m m (dB 16 (dB 28 M at 3 s P IP 14 25 A 12 22 Vdd=3V 10 19 Vdd=3V 8 16 4.5 4.8 5.1 5.4 5.7 6 4.5 4.8 5.1 5.4 5.7 6 FREQUENCY (GHz) FREQUENCY (GHz) +25C +85C -40C +25C +85C -40C
Output Ip3 and Total supply Current vs. Output Ip3 and Total supply Current vs. supply Voltage @ 4800 MHz [3] supply Voltage @ 5900 MHz [3]
34 120 34 125 32 110 32 110 30 100 28 90 30 95 ) 26 80 ) m Idd m 28 80 Idd 24 70 (dB (m (dB (m 3 A 3 26 65 A 22 60 IP ) IP ) 20 50 24 50 18 40 22 35 16 30 14 20 20 20 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 Voltage Supply (V) Voltage Supply (V) IP3-3V Idd-3V IP3-3V Idd-3V IP3-5V Idd-5V IP3-5V Idd-5V [1] Vdd = 5V, Rbias = 825Ω [2] Vdd = 3V, Rbias = 5.76kΩ [3] Rbias = 825Ω for Vdd = 5V, Rbias = 5.76kΩ for Vdd = 3V For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
3
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Gain, Noise Figure & Rbias @ 5900 MHz Output IP3 vs. Rbias @ 5900 MHz Gain, Noise Figure & Rbias @ 4800 MHz Output IP3 vs. Rbias @ 4800 MHz Gain, Power & Noise Figure vs. Supply Voltage @ 5900 MHz Gain, Power & Noise Figure vs. Supply Voltage @ 4800 MHz Power Compression @ 5900 MHz Power Compression @ 5900 MHz Power Compression @ 4800 MHz Output IP3 and Total Supply Current vs. Supply Voltage @ 5900 MHz Output IP3 and Total Supply Current vs. Supply Voltage @ 4800 MHz Output IP3 vs. Temperature Psat vs. Temperature P1dB vs. Temperature Noise Figure vs. Temperature Reverse Isolation vs. Temperature Output Return Loss vs. Temperature Input Return Loss vs. Temperature Gain vs. Temperature Gain vs. Temperature Broadband Gain & Return Loss Power Compression @ 4800 MHz Absolute Bias Resistor Range & Recommended Bias Resistor Values Absolute Maximum Ratings Typical Supply Current vs. Supply Voltage Outline Drawing Package Information Pin Descriptions Application Circuit Evaluation PCB List of Materials
