Datasheet HMC1126 (Analog Devices) - 4
ОписаниеGaAs, pHEMT, MMIC, Power Amplifier, 2 GHz to 50 GHz
Страниц / Страница16 / 4 — HMC1126. Data Sheet. 26 GHz TO 40 GHz FREQUENCY RANGE. Table 3. …
ВерсияC
Формат / Размер файлаPDF / 333 Кб
HMC1126. Data Sheet. 26 GHz TO 40 GHz FREQUENCY RANGE. Table 3. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit
HMC1126 Data Sheet 26 GHz TO 40 GHz FREQUENCY RANGE Table 3 Parameter Symbol Test Conditions/Comments Min Typ Max Unit
24 предложений от 13 поставщиков
Усилитель IC и модуль RF, RF Amp Chip Single Power Amp 50GHz 8V 5Pin Die
Рутоника
HMC1126
11 948 ₽
HMC1126
12 576 ₽
HMC1126ACEZ
от 36 050 ₽
Зенер
Россия и страны ТС
HMC1126-SX
от 65 232 ₽
TA = 25°C, VDD = 5 V, VGG2 = 1.4 V, IDD = 65 mA, unless otherwise stated. Adjust VGG1 between −2 V to 0 V to achieve IDD = 65 mA typical.
Table 3. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE 26 40 GHz GAIN 8 11 dB Gain Variation Over Temperature 0.005 dB/°C RETURN LOSS Input 20 dB Output 218 dB OUTPUT Output Power for 1 dB Compression P1dB 13 16 dBm Saturated Output Power PSAT 20.5 dBm Output Third-Order Intercept IP3 Measurement taken at POUT/tone = 10 dBm 28 dBm NOISE FIGURE 4 TOTAL SUPPLY CURRENT IDD VDD = 4 V, VDD = 5 V, VDD = 6 V, VDD = 7 V, or VDD = 8 V 65 mA
40 GHz TO 50 GHz FREQUENCY RANGE
Table 4. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE 40 50 GHz GAIN 8 10.5 dB Gain Variation Over Temperature 0.009 dB/°C RETURN LOSS Input 12 dB Output 12 dB OUTPUT Output Power for 1 dB Compression P1dB 10 13 dBm Saturated Output Power PSAT 18 dBm Output Third-Order Intercept IP3 Measurement taken at POUT/tone = 10 dBm 24 dBm NOISE FIGURE 5 TOTAL SUPPLY CURRENT IDD VDD = 4 V, VDD = 5 V, VDD = 6 V, VDD = 7 V, or VDD = 8 V 65 mA Rev. C | Page 4 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY ELECTRICAL SPECIFICATIONS 2 GHz TO 10 GHz FREQUENCY RANGE 10 GHz TO 26 GHz FREQUENCY RANGE 26 GHz TO 40 GHz FREQUENCY RANGE 40 GHz TO 50 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions Mounting Wire Bonding APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
