Datasheet HMC566LP4E (Analog Devices) - 4
ОписаниеGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 28 - 36 GHz
Страниц / Страница6 / 4 — HMC566LP4E. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 28 - 36 GHz. Typical …
Формат / Размер файлаPDF / 417 Кб
HMC566LP4E. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 28 - 36 GHz. Typical Supply Current vs. Vdd. Pin Descriptions
HMC566LP4E GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 28 - 36 GHz Typical Supply Current vs Vdd Pin Descriptions
20 предложений от 12 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
HMC566LP4ETR
51 ₽
Зенер
Россия и страны ТС
HMC566LP4ETR
от 3 637 ₽
HMC566LP4ETR
от 7 638 ₽
727GS
HMC566LP4ETR
HMC566LP4E
v02.0609
7
Vdd (V) idd (mA) +2.5 79 T +3.0 82 m +3.5 85 s Note: Amplifier will operate over full voltage ranges shown above. e - is
Pin Descriptions
o pin Number function Description interface schematic 1, 2, 4 - 7, 12 - 15, This pins and exposed ground paddle GND w N 17 - 19, 24 must be connected to rf/DC ground. lo This pin is AC coupled 3 rfiN and matched to 50 ohms. s - 8 - 11 N/C No Connection r This pin is AC coupled 16 rfoUT ie and matched to 50 ohms. lif power supply Voltage for the amplifier. external bypass 23, 22, 21, 20 Vdd1, 2, 3, 4 p capacitors of 100 pf, 10 nf and 4.7 µf are required. m A
Application Circuit
Info F rmoatri op n rfiurcne is ,h ed d ebly ivAe n r al y o g aDn evdic eto s i p s bla eli c evee d otro dbe e ras: cc uH ratite tiatne d M reli iac bl reo . w Ho av wev e er , Cno o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No O P r h d o e ne r O : 7 n 81- -3li 2n 9 e - 4 a 7 t 0 ww 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
7 - 4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p li coarti o ap n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
