Datasheet HMC376LP3, 376LP3E (Analog Devices) - 6
ОписаниеGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 700 - 1000 MHz
Страниц / Страница6 / 6 — HMC376LP3 / 376LP3E. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 700 - 1000 …
Формат / Размер файлаPDF / 318 Кб
HMC376LP3 / 376LP3E. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 700 - 1000 MHz. Evaluation PCB
HMC376LP3 / 376LP3E GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 700 - 1000 MHz Evaluation PCB
22 предложений от 13 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
HMC376LP3E
13 ₽
HMC376LP3E
1 513 ₽
Эиком
HMC376LP3E
от 2 081 ₽
Элитан
HMC376LP3E
2 138 ₽
HMC376LP3 / 376LP3E
v01.0610
7
Evaluation PCB
T E - SM IS W NO O - L S R IE IF L P M A
List of Materials for Evaluation PCB 112585 [1]
The circuit board used in the application should use Item Description RF circuit design techniques. Signal lines should J1 - J2 PCB Mount SMA RF Connector have 50 Ohm impedance while the package ground J3 - J4 DC Pin leads and exposed paddle should be connected C1 1000 pF Capacitor, 0402 Pkg. directly to the ground plane similar to that shown. C2 1000 pF Capacitor, 0603 Pkg. A sufficient number of via holes should be used to C3 15000 pF Capacitor, 0603 Pkg. connect the top and bottom ground planes. The L1 18 nH Inductor, 0603 Pkg. evaluation circuit board shown is available from L2 47 nH Inductor, 0603 Pkg. Hittite upon request. R1 Resistor, 0402 Pkg. U1 HMC376LP3 / HMC376LP3E Amplifi er PCB [2] 112580 Evaluation PCB [1] Reference this number when ordering complete evaluation PCB [2] Circuit Board Material: Rogers 4350 Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Pho - n 25 e: 7 0- 81 3 3 3 2 4 9- 3 F 470 ax: 978 0 • Order o - n 25 lin 0 e a-t 3373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
7 - 6
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
