Datasheet HMC372LP3, 372LP3E (Analog Devices) - 5
ОписаниеGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 700 - 1000 MHz
Страниц / Страница8 / 5 — HMC372LP3 / 372LP3E. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 700 - 1000 …
Формат / Размер файлаPDF / 397 Кб
HMC372LP3 / 372LP3E. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 700 - 1000 MHz. Outline Drawing. Package Information. 7 - 56
HMC372LP3 / 372LP3E GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 700 - 1000 MHz Outline Drawing Package Information 7 - 56
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
HMC372LP3ETR
13 ₽
HMC372LP3ETR
955 ₽
Зенер
Россия и страны ТС
HMC372LP3ETR
1 246 ₽
HMC372LP3ETR
HMC372LP3 / 372LP3E
v03.0610
7
Outline Drawing
T E - SM IS W NO O - L S NOTES: 1. LEADFRAME MATERIAL: COPPER ALLOY R 2. DIMENSIONS ARE IN INCHES [MILLIMETERS] IE 3. LEAD SPACING TOLERANCE IS NON-CUMULATIVE 4. PAD BURR LENGTH SHALL BE 0.15mm MAXIMUM. IF PAD BURR HEIGHT SHALL BE 0.05mm MAXIMUM. L 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm. P 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND. 7. REFER TO HITTITE APPLICATION NOTE FOR SUGGESTED LAND PATTERN. M A
Package Information
Part Number Package Body Material Lead Finish MSL Rating Package Marking [3] [1] H372 HMC372LP3 Low Stress Injection Molded Plastic Sn/Pb Solder MSL1 XXXX [2] H372 HMC372LP3E RoHS-compliant Low Stress Injection Molded Plastic 100% matte Sn MSL1 XXXX [1] Max peak refl ow temperature of 235 °C [2] Max peak refl ow temperature of 260 °C [3] 4-Digit lot number XXXX Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m
7 - 56
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
