Datasheet HMC341LC3B (Analog Devices) - 4
ОписаниеSMT GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 21 - 29 GHz
Страниц / Страница6 / 4 — HMC341LC3B. SMT GaAs PHEMT MMIC. LOW NOISE AMPLIFIER, 21 - 29 GHz. …
Формат / Размер файлаPDF / 335 Кб
HMC341LC3B. SMT GaAs PHEMT MMIC. LOW NOISE AMPLIFIER, 21 - 29 GHz. Absolute Maximum Ratings. Typical Supply Current vs. Vdd
HMC341LC3B SMT GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 21 - 29 GHz Absolute Maximum Ratings Typical Supply Current vs Vdd
Усилитель IC и модуль RF, RF Amp Chip Single Low Noise Amplifier 29000MHz 5.5V 12Pin QFN T/R
HMC341LC3BTR
13 ₽
HMC341LC3BTR-R5
4 603 ₽
HMC341LC3BTR
9 269 ₽
Элитан
HMC341LC3BTR-R5
13 628 ₽
HMC341LC3B
v03.0514
SMT GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 21 - 29 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd
Drain Bias Voltage (Vdd) +5.5 Vdc Vdd (Vdc) Idd (mA) RF Input Power (RFIN)(Vdd = +3.0 Vdc) +5 dBm +2.7 34 T Channel Temperature 175 °C +3.0 35 M Continuous Pdiss (T= 85 °C) +4.0 38 0.489 W (derate 5.43 mW/°C above 85 °C) +5.0 41 Thermal Resistance 184 °C/W Note: Amplifier will operate over full voltage ranges shown above. (channel to ground paddle) S - S Storage Temperature -65 to +150 °C R Operating Temperature -40 to +85 °C IE ELECTROSTATIC SENSITIVE DEVICE OBSERVE HANDLING PRECAUTIONS LIF P
Outline Drawing
M E A IS O W N LO NOTES: 1. PACKAGE BODY MATERIAL: ALUMINA. 2. LEAD AND GROUND PADDLE PLATING: GOLD FLASH OVER NICKEL. 3. DIMENSIONS ARE IN INCHES (MILLIMETERS). 4. LEAD SPACING TOLERANCE IS NON-CUMULATIVE. 5. PACKAGE WARP SHALL NOT EXCEED 0.05MM DATUM – C – 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND.
Package Information
Part Number Package Body Material Lead Finish MSL Rating Package Marking [2] HMC341LC3B Alumina, White Gold over Nickel MSL3 [1] H341 XXXX [1] Max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
