Datasheet ADPA7006CHIP (Analog Devices) - 2
Описание18 GHz to 44 GHz, GaAs, pHEMT, MMIC, 1/2 W Power Amplifier
Страниц / Страница24 / 2 — ADPA7006CHIP. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY. …
Формат / Размер файлаPDF / 465 Кб
ADPA7006CHIP. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY. 7/2019—Revision 0: Initial Version
ADPA7006CHIP Data Sheet TABLE OF CONTENTS REVISION HISTORY 7/2019—Revision 0: Initial Version
5 предложений от 5 поставщиков
IC RF AMP GPS 18GHZ-44GHZ DIE
ADPA7006CHIP
12 792 ₽
ADPA7006CHIP
13 193 ₽
ADPA7006CHIP
13 891 ₽
Элитан
ADPA7006CHIP
15 121 ₽
link to page 1 link to page 1 link to page 1 link to page 1 link to page 2 link to page 3 link to page 3 link to page 3 link to page 4 link to page 4 link to page 5 link to page 5 link to page 6 link to page 6 link to page 7 link to page 14 link to page 15 link to page 16 link to page 16 link to page 16 link to page 18 link to page 18 link to page 18 link to page 18 link to page 20 link to page 20 link to page 20 link to page 22 link to page 23 link to page 23 link to page 23 link to page 24 link to page 24
Features .. 1  Applications Information .. 16  Applications ... 1  Mounting and Bonding Techniques for Millimeterwave GaAs Functional Block Diagram .. 1  MMICs ... 16  General Description ... 1  Biasing the ADPA7006CHIP with the HMC980LP4E .. 18  Revision History ... 2  Application Circuit Setup .. 18  Specifications ... 3  Limiting VGATE for the ADPA7006CHIP VGGx AMR (Absolute Maximum Rating) Requirement .. 18  18 GHz to 20 GHz Frequency Range ... 3  HMC980LP4E Bias Sequence ... 20  20 GHz to 28 GHz Frequency Range ... 3  Constant Drain Current Biasing vs. Constant Gate Voltage 28 GHz to 36 GHz Frequency Range ... 4  Biasing .. 20  36 GHz to 44 GHz Frequency Range ... 4  Typical Application Circuit ... 22  Absolute Maximum Ratings .. 5  Assembly Diagrams .. 23  ESD Caution .. 5  Primary Assembly Diagram.. 23  Pin Configuration and Function Descriptions ... 6  Alternate Assembly Diagram .. 23  Interface Schematics... 6  Outline Dimensions ... 24  Typical Performance Characteristic ... 7  Ordering Guide .. 24  Constant Drain Current (IDD) Operation .. 14  Theory of Operation .. 15
Rev. 0 | Page 2 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 18 GHz TO 20 GHz FREQUENCY RANGE 20 GHz TO 28 GHz FREQUENCY RANGE 28 GHz TO 36 GHz FREQUENCY RANGE 36 GHz TO 44 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTIC CONSTANT DRAIN CURRENT (IDD) OPERATION THEORY OF OPERATION APPLICATIONS INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions Mounting Wire Bonding BIASING THE ADPA7006CHIP WITH THE HMC980LP4E APPLICATION CIRCUIT SETUP LIMITING VGATE FOR THE ADPA7006CHIP VGGx AMR (ABSOLUTE MAXIMUM RATING) REQUIREMENT HMC980LP4E BIAS SEQUENCE Power-Up Sequence Power-Down Sequence CONSTANT DRAIN CURRENT BIASING vs. CONSTANT GATE VOLTAGE BIASING TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAMS OUTLINE DIMENSIONS ORDERING GUIDE
