Datasheet ADTR1107 (Analog Devices) - 5
Описание6 GHz to 18 GHz, Front-End IC
Страниц / Страница28 / 5 — Data Sheet. ADTR1107. Parameter Symbol. Min. Typ. Max. Unit. Test. …
ВерсияA
Формат / Размер файлаPDF / 943 Кб
Data Sheet. ADTR1107. Parameter Symbol. Min. Typ. Max. Unit. Test. Conditions/Comments. Table 5. Parameter Symbol
Data Sheet ADTR1107 Parameter Symbol Min Typ Max Unit Test Conditions/Comments Table 5 Parameter Symbol
30 предложений от 14 поставщиков
Входной каскад с малошумящим усилителем 6.5...21.5дБ 6....18ГГц 24-Pin LGA EP лента на катушке
ADTR1107ACCZ-R7
10 851 ₽
Элрус
ADTR1107ACCZ
14 811 ₽
ЭИК
ADTR1107ACCZ-R7
от 26 908 ₽
727GS
ADTR1107ACCZ-R7
OIP3 25.5 dBm ANT to RX_OUT POUT per tone = 0 dBm Noise Figure 3 dB ANT to RX_OUT Isolation ANT to TX_IN 26 dB Transmit state off RX_OUT to TX_IN 46 dB Transmit state off RF Settling Time 0.1 dB 17 ns 50% CTRL_SW to 0.1 dB of final RF output 0.05 dB 22 ns 50% CTRL_SW to 0.05 dB of final RF output Switching Speed Rise and Fall Time tRISE, tFALL 2 ns 10% to 90% of RF output Turn On and Turn Off Time tON, tOFF 10 ns 50% CTRL_SW to 90% of RF output VDD_LNA 2.0 3.3 3.6 V IDQ_LNA 80 mA Self biased SPDT switch bias at VDD_SW = 3.3 V, VSS_SW = −3.3 V.
Table 5. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
SUPPLY CURRENT VDD_SW and VSS_SW Positive IDD_SW 14 μA Negative ISS_SW 120 μA DIGITAL CONTROL INPUTS CTRL_SW Voltage Low 0 0.8 V High 1.2 3.3 V Current (Low and High) <1 μA Rev. A | Page 5 of 28 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS TRANSMIT STATE RECEIVE STATE THEORY OF OPERATION APPLICATIONS INFORMATION RECOMMENDED BIAS SEQUENCING TYPICAL APPLICATION CIRCUIT INTERFACING THE ADTR1107 TO THE ADAR1000 X BAND AND KU BAND BEAMFORMER OUTLINE DIMENSIONS ORDERING GUIDE
