Datasheet HMC1132PM5E (Analog Devices) - 3
Описание27 GHz to 32 GHz, GaAs, pHEMT, MMIC Power Amplifier
Страниц / Страница17 / 3 — Data Sheet. HMC1132PM5E. SPECIFICATIONS ELECTRICAL SPECIFICATIONS. Table …
Формат / Размер файлаPDF / 351 Кб
Data Sheet. HMC1132PM5E. SPECIFICATIONS ELECTRICAL SPECIFICATIONS. Table 1. Parameter. Symbol Min Typ. Max Unit
Data Sheet HMC1132PM5E SPECIFICATIONS ELECTRICAL SPECIFICATIONS Table 1 Parameter Symbol Min Typ Max Unit
17 предложений от 9 поставщиков
, RF Amp Single Power Amp 32GHz 6V 32-Pin LFCSP EP T/R
HMC1132PM5E
6 752 ₽
HMC1132PM5E
9 559 ₽
HMC1132PM5E
от 16 142 ₽
Элитан
HMC1132PM5E
18 270 ₽
TA = 25°C, VDD1 = VDD2 = 5 V, quiescent current (IDDQ) = 650 mA, and frequency range = 27 GHz to 29 GHz, unless otherwise noted.
Table 1. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 27 29 GHz GAIN 19 22 dB Gain Variation over Temperature 0.028 dB/°C RETURN LOSS Input 7 dB Output 9 dB POWER Output Power for 1 dB Compression P1dB 26.5 28.5 dBm Saturated Output Power PSAT 29.5 dBm OUTPUT THIRD-ORDER INTERCEPT IP3 37 dBm Measurement taken at 5 V, 650 mA, output power (POUT) per tone = 20 dBm NOISE FIGURE NF 7 dB SUPPLY VOLTAGE VDD 4 6 V QUIESCENT SUPPLY CURRENT IDDQ 500 750 mA Adjust the gate bias voltage (VGG) from −2 V up to 0 V to achieve desired quiescent current (IDDQ) TA = 25°C, VDD1 = VDD2 = 5 V, quiescent current (IDDQ) = 650 mA, and frequency range = 29 GHz to 32 GHz, unless otherwise noted.
Table 2. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 29 32 GHz GAIN 21 24 dB Gain Variation over Temperature 0.034 dB/°C RETURN LOSS Input 11 dB Output 14 dB POWER Output Power for 1 dB Compression P1dB 27 29 dBm Saturated Output Power PSAT 29.5 dBm OUTPUT THIRD-ORDER INTERCEPT IP3 37 dBm Measurement taken at 5 V, 650 mA, POUT per tone = 20 dBm NOISE FIGURE NF 5.5 dB SUPPLY VOLTAGE VDD 4 6 V QUIESCENT SUPPLY CURRENT IDDQ 500 750 mA Adjust the gate bias voltage (VGG) from −2 V up to 0 V to achieve desired quiescent current (IDDQ) Rev. 0 | Page 3 of 17 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Application Circuit Evaluation Board Bill of Materials Evaluation Board Schematic Outline Dimensions Ordering Guide
