Datasheet HMC7149 (Analog Devices) - 6
Описание10 WATT GaN MMIC POWER AMPLIFIER, 6 - 18 GHz
Страниц / Страница10 / 6 — HMC7149. 10 WATT GaN MMIC POWER AMPLIFIER,. 6 - 18 GHz. Reverse Isolation …
Формат / Размер файлаPDF / 944 Кб
HMC7149. 10 WATT GaN MMIC POWER AMPLIFIER,. 6 - 18 GHz. Reverse Isolation vs. Temperature
HMC7149 10 WATT GaN MMIC POWER AMPLIFIER, 6 - 18 GHz Reverse Isolation vs Temperature
6 предложений от 6 поставщиков
, RF Amp Single Power Amp 18GHz 32V 6Pin Die Tray
HMC7149-SX
100 818 ₽
ЧипСити
HMC7149-SX
298 796 ₽
HMC7149-SX
343 780 ₽
HMC7149-SX
HMC7149
v
10 WATT GaN MMIC POWER AMPLIFIER, 6 - 18 GHz Reverse Isolation vs. Temperature Second Harmomonics vs. Supply Voltage
0 70 IP -10 60 H -20 ) (dBc) 50 -30 C (dB N -40 40 IO T -50 LA HARMONI 30 R - C O IS -60 20 E -70 SECOND 10 W -80 -90 0 O 6 8 10 12 14 16 18 6 8 10 12 14 16 18 FREQUENCY (GHz) FREQUENCY(GHz) +25 C +85 C -40 C 24V 28V 32V R & P A E
Second Harmomonics vs. Supply Current Second Harmomonics vs. Pout
IN 70 70 60 60 (dBc) 50 (dBc) C 50 C S - L 40 40 R HARMONI 30 HARMONI 30 IE 20 20 SECOND SECOND LIF 10 10 P 0 0 6 8 10 12 14 16 18 6 8 10 12 14 16 18 M FREQUENCY(GHz) FREQUENCY(GHz) A 340 mA 680 mA 1360 mA 24 dBm 28 dBm 32 dBm 26 dBm 30 dBm
Power Dissipation
45 40 (W) 35 30 DISSIPATION 25 20 POWER 15 10 0 3 6 9 12 15 18 21 24 27 30 INPUT POWER (dBm) 6 GHz 12 GHz 18 GHz 8 GHz 14 GHz 10 GHz 16 GHz FIo nf r p orm raiticoe n , d fur e nislihvee d rby a y A n n d t alog o p Devila ce cs e o is b rd eli e ev res d : A to n b a e lao ccg D urat e e v anic d eresli, I abl n e c . .H, 1 Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 owever, no For price, delivery, and to place orders: Analog Devices, In c., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other Phone: 781-329-4700 • Order On-line at www.analog.com One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Phone: 781-329-4700 • Order online at www.analog.com
6
Application Support: Phone: 1-800-ANALOG-D Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
