Datasheet HMC454ST89, 454ST89E (Analog Devices) - 10
ОписаниеInGaP HBT ½ WATT HIGH IP3 AMPLIFIER, 0.4 - 2.5 GHz
Страниц / Страница12 / 10 — HMC454ST89 / 454ST89E. InGaP HBT ½ WATT HIGH IP3. AMPLIFIER, 0.4 - 2.5 …
Формат / Размер файлаPDF / 629 Кб
HMC454ST89 / 454ST89E. InGaP HBT ½ WATT HIGH IP3. AMPLIFIER, 0.4 - 2.5 GHz. 1960 & 2140 MHz Evaluation PCB
HMC454ST89 / 454ST89E InGaP HBT ½ WATT HIGH IP3 AMPLIFIER, 0.4 - 2.5 GHz 1960 & 2140 MHz Evaluation PCB
23 предложений от 11 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
HMC454ST89ETR
554 ₽
Зенер
Россия и страны ТС
HMC454ST89ETR
от 755 ₽
HMC454ST89ETR
Hittite
HMC454ST89ETR
v05.0710
9 T R - SM E W O R & P A E IN S - L R IE
List of Materials for Evaluation PCB 107749 [1]
IF The circuit board used in this application should use Item Description L RF circuit design techniques. Signal lines should J1 - J2 PCB Mount SMA Connector P have 50 Ohm impedance while the package ground J3 - J4 DC Pins M leads and exposed paddle should be connected C1 1.0 pF Capacitor, 0402 Pkg. A directly to the ground plane similar to that shown. C2 1.2 pF Capacitor, 0402 Pkg. A sufficient number of via holes should be used to C3 3.0 pF Capacitor, 0402 Pkg. connect the top and bottom ground planes. The C4 100 pF Capacitor, 0402 Pkg. evaluation board should be mounted to an appro- C5 2.2 μF Capacitor, Tantalum priate heat sink. The evaluation circuit board shown L1 8.2 nH Inductor, 0402 Pkg. is available from Hittite upon request. U1 HMC454ST89 / HMC454ST89E PCB [2] 107747 Evaluation PCB, 10 mils [1] Reference this number when ordering complete evaluation PCB [2] Circuit Board Material: Rogers 4350, Er = 3.48 Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
9 - 199
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
