Datasheet HMC981LP3E (Analog Devices) - 2
ОписаниеACTIVE BIAS CONTROLLER
Страниц / Страница17 / 2 — HMC981LP3E. ACTIVE BIAS CONTROLLER. Electrical Specifications, T = +25°C, …
Формат / Размер файлаPDF / 998 Кб
HMC981LP3E. ACTIVE BIAS CONTROLLER. Electrical Specifications, T = +25°C, VDD=8V, VDIG= 3.3V, Depletion Master
HMC981LP3E ACTIVE BIAS CONTROLLER Electrical Specifications, T = +25°C, VDD=8V, VDIG= 3.3V, Depletion Master
28 предложений от 15 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Управление питанием - Специальные
HMC981LP3ETR
от 765 ₽
ЧипСити
HMC981LP3ETR
1 570 ₽
HMC981LP3ETR
1 570 ₽
Hi-Tech Circuit Group
HMC981LP3ETR
HMC981LP3E
v01.0411
ACTIVE BIAS CONTROLLER Electrical Specifications, T = +25°C, VDD=8V, VDIG= 3.3V, Depletion Master A
Unless Otherwise Noted Parameter Symbol Conditions Min. Typ. Max. Units Supply Voltage Vdd 4 12 V EN = VDIG 7 mA VDD = 4V EN = GND 3 mA VDD Quiescent Current IDD EN = VDIG 7.5 mA VDD = 8V EN = GND 4 mA VDIG= 3.3 V 3 mA VDIG Quiescent Current IDIG VDIG= 5 V 5 mA Negative Voltage Output VNEG -2.5 V Oscillator Frequency FOSC 300 kHz Voltage Reference VREF 1.42 V Vinlow 1 V Enable Input Threshold ENTHRS Vinhigh 1.4 V 13 Vinlow 1 V Switch Input Threshold SWTHRS Vinhigh 1.4 V Vinlow 1 V T Short Circuit Disable Input Threshold DSCTHRS Vinhigh 1.4 V M
VDRAIN Characteristics
SW=GND 20 80 mA DRAIN Current Adjustment Range IDRAIN SW=VDIG 80 200 mA S - S DRAIN Current Change Over Digital Voltage VDRAIN set to 8V, 0.4 %/V ΔIDRAINV R IDRAIN set to 160 mA DRAIN Current Change Over Temperature 0.02 %/C DRAIN Range VDRAIN 4 12 V LLE VDRAIN set to 8V, VDRAIN Change Over Temperature ΔVDRAIN 1.5 %/C IDRAIN set to 160 mA O
VNEG Characteristics
R Negative Voltage Output VNEG -2.5 V T VDD= 4V 0 8 mA N VNEG Current Sink INEG VDD= 8V 0 15 mA O
VGATE Characteristics
GATE Current Supply IG -0.8 0.8 mA S C VGATE Low Level VG_MIN VNEG V IA VGATE High Level VG_MAX VNEG+4.5 V B
VG2 Characteristics
VG2<1.5V -0.1 0.1 mA VG2 Current Supply IG2 VG2>1.5V -1 1 mA VG2 Adjustment Range VG2 1 VDD-1.3 V
VDIG Characteristics
Adjustment Range VDIG 3.3 5 V VDD= 8 V, VDIG Quiescent Current IDIG 3 mA VDIG=EN =3.3 V
SW Characteristics
SW= GND 10 Ohm Internal Switch Resistance RDS_ON SW=VDIG 5 Ohm Information furnish F e o d r p by A rnic alo e g , d Devi ecleis vie s rby eli, a eve nd t d to b o p e a l cc a ur c at e o e an r d d releiars ble , p . Ho le we a vesr, e c no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ontact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 2 Elizabeth Drive, Chelmsford, MA 01824 Phon rights of third parties that may result from its use. Specifications subject to change without notice. No e: 9 Ph 7 o 8 n - e 2 : 750 81- - 3 3 2 3 9- 4 4 3 F 70 ax 0 • O : 9 rde 7 r o8 nl-i2 n 50 e at -33 ww 7 w. 3 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. analog.com
13 - 2
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptiptliec.actio o m n Support: Phone: 1-800-ANALOG-D
