Datasheet HMC601LP4, 601LP4E (Analog Devices) - 8
Описание75 dB, FAST SETTLING, LOGARITHMIC DETECTOR / CONTROLLER 10 - 4000 MHz
Страниц / Страница8 / 8 — HMC601LP4 / 601LP4E. 75 dB, FAST SETTLING, LOGARITHMIC. DETECTOR / …
Формат / Размер файлаPDF / 500 Кб
HMC601LP4 / 601LP4E. 75 dB, FAST SETTLING, LOGARITHMIC. DETECTOR / CONTROLLER 10 - 4000 MHz
HMC601LP4 / 601LP4E 75 dB, FAST SETTLING, LOGARITHMIC DETECTOR / CONTROLLER 10 - 4000 MHz
12 предложений от 9 поставщиков
75 dB, FAST SETTLING, LOGARITHMIC DETECTOR / CONTROLLER 10 - 4000 MHz | IC RF DETECT 10MHZ-4GHZ 24QFN
727GS
HMC601LP4E
4.02 ₽
HMC601LP4E
от 1 979 ₽
HMC601LP4E
2 620 ₽
Элитан
HMC601LP4E
3 736 ₽
HMC601LP4 / 601LP4E
v01.0509
75 dB, FAST SETTLING, LOGARITHMIC DETECTOR / CONTROLLER 10 - 4000 MHz Application & Evaluation PCB Schematic
12 T S - SM R O T Notes C Note 1: The HMC601LP4 & HMC601LP4E evaluation boards are pre-assembled for single-ended input, and detector/RSSI mode. E Note 2: For single-ended input operation, use the INP port and make no connection to INN. INN is AC coupled to ground by C2 T Note 3: For differential input, remove C2, and install a 1000pF capacitor in series with INN at location shown. E Note 4: For detector mode, connect high impedence volt meter to the LOGOUT port, and make no connection to VSET. LOGOUT is shorted to VSET by R3, as required for detector mode. R D Note 5: For controller mode, remove R3 and make appropriate connection to LOGOUT and VSET. In controller mode, the E LOGOUT output can be used to drive a variable gain amplifi er, or a variable attenuator, either directly or through a buffer W or microcontroller. VSET should be connected to an external supply, typically between +0.6 and +1.9V. O
Power-Up Timing Diagram
P Information furnis F heod r pri by An ce, de alog Devi lcievs eir s y b , a eliev nd to pla ed to be accu ce o rate anrder d relia sbl, pl e. H ease co owever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone: 978 rights of third parties that may result from its use. Specifications subject to change without notice. No Ph - o 25 ne 0 : 7 -3 81- 3 3 4 29 3 F -470 ax: 978 0 • Orde - r o 25 nlin 0- e a3 t 373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
12 - 17
Order On-l Trademarks and registered trademarks are the property of their respective owners. ine at www.hit A ti p te.co plicati m on Support: Phone: 1-800-ANALOG-D
