Datasheet AD8319 (Analog Devices) - 8
Описание1 MHz to 10 GHz, 45 dB Log Detector/Controller
Страниц / Страница19 / 8 — AD8319. Data Sheet. 2.00. 2.0. 1.75. 1.5. 1.50. 1.0. 1.25. 0.5. B) d. …
ВерсияD
AD8319. Data Sheet. 2.00. 2.0. 1.75. 1.5. 1.50. 1.0. 1.25. 0.5. B) d. (V). R (. 1.00. RRO. 0.75. –0.5. 0.50. –1.0. 0.25. –1.5. –2.0. –60. –50. –40. –30. –20. –10. PIN (dBm)
AD8319 Data Sheet 2.00 2.0 1.75 1.5 1.50 1.0 1.25 0.5 B) d (V) R ( 1.00 RRO 0.75 –0.5 0.50 –1.0 0.25 –1.5 –2.0 –60 –50 –40 –30 –20 –10 PIN (dBm)
Модуль RF, IC и деталь , RF Detector 1MHz to 10000MHz 12dBm 8Pin LFCSP EP Tray
AD8319ACPZ-WP
64 ₽
AD8319ACPZ-WP
871 ₽
AD8319ACPZ-WP
AD8319ACPZ-WP
AD8319 Data Sheet 2.00 2.0 2.00 2.0 1.75 1.5 1.75 1.5 1.50 1.0 1.50 1.0 1.25 0.5 ) 1.25 0.5 ) B B) d (V (d (V) R 0 R ( UT 1.00 0 O 1.00 UT O O V RR V RRO E E 0.75 –0.5 0.75 –0.5 0.50 –1.0 0.50 –1.0 0.25 –1.5 0.25 –1.5 0 –2.0 0 –2.0 –60 –50 –40 –30 –20 –10 0 10 –60 –50 –40 –30 –20 –10 0 10
012 009
PIN (dBm) PIN (dBm)
05705- 05705- Figure 9. VOUT and Log Conformance Error vs. Input Amplitude at 900 MHz, Figure 12. VOUT and Log Conformance Error vs. Input Amplitude at 3.6 GHz, Multiple Devices, RTADJ = 18 kΩ Multiple Devices, RTADJ = 8 kΩ
2.00 2.0 2.00 2.0 1.75 1.5 1.75 1.5 1.50 1.0 1.50 1.0 1.25 0.5 1.25 0.5 B) B) d d (V) (V) 1.00 R ( 0 R ( UT 0 1.00 UT O O V RRO V RRO E E 0.75 –0.5 0.75 –0.5 0.50 –1.0 0.50 –1.0 0.25 –1.5 0.25 –1.5 0 –2.0 0 –2.0 –60 –50 –40 –30 –20 –10 0 10
010
013
PIN (dBm)
05705-
P IN (dBm)
05705- Figure 10. VOUT and Log Conformance Error vs. Input Amplitude at 1.9 GHz, Figure 13. VOUT and Log Conformance Error vs. Input Amplitude at 5.8 GHz, Multiple Devices, RTADJ = 8 kΩ Multiple Devices, RTADJ = 500 Ω
2.00 2.0 2.00 2.0 1.75 1.5 1.75 1.5 1.50 1.0 1.50 1.0 1.25 0.5 1.25 0.5 B) B) d d (V) (V) R ( 1.00 R ( 1.00 0 UT 0 UT O O V RRO V RRO E E 0.75 –0.5 0.75 –0.5 0.50 –1.0 0.50 –1.0 0.25 –1.5 0.25 –1.5 0 –2.0 0 –2.0 –60 –50 –40 –30 –20 –10 0 10
011
014
P P IN (dBm)
05705-
IN (dBm)
05705- Figure 11. VOUT and Log Conformance Error vs. Input Amplitude at 2.2 GHz, Figure 14. VOUT and Log Conformance Error vs. Input Amplitude at 8.0 GHz, Multiple Devices, RTADJ = 8 kΩ Multiple Devices, RTADJ = Open, Error Calculated from PIN = −34 dBm to PIN = −16 dBm Rev. D | Page 8 of 19 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION USING THE AD8319 BASIC CONNECTIONS INPUT SIGNAL COUPLING OUTPUT INTERFACE SETPOINT INTERFACE TEMPERATURE COMPENSATION OF OUTPUT VOLTAGE MEASUREMENT MODE SETTING THE OUTPUT SLOPE IN MEASUREMENT MODE CONTROLLER MODE OUTPUT FILTERING OPERATION BEYOND 8 GHz EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
