Datasheet AD8418A (Analog Devices) - 5
ОписаниеBidirectional, Zero-Drift, Current Sense Amplifier
Страниц / Страница18 / 5 — Data Sheet. AD8418A. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. –IN 1. …
ВерсияE
Формат / Размер файлаPDF / 463 Кб
Data Sheet. AD8418A. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. –IN 1. 8 +IN. GND 2. AD8418A 7 VREF1. TOP VIEW. REF2. 6 VS
Data Sheet AD8418A PIN CONFIGURATION AND FUNCTION DESCRIPTIONS –IN 1 8 +IN GND 2 AD8418A 7 VREF1 TOP VIEW REF2 6 VS
39 предложений от 16 поставщиков
Зенер
Россия и страны ТС
AD8418AWBRMZ
от 132 ₽
727GS
AD8418AWBRMZ
от 213 ₽
IC Home
AD8418AWBRMZ
276 ₽
Элитан
AD8418AWBRMZ
329 ₽
Data Sheet AD8418A PIN CONFIGURATION AND FUNCTION DESCRIPTIONS –IN 1 8 +IN GND 2 AD8418A 7 VREF1 V TOP VIEW REF2 3 6 VS (Not to Scale) NC 4 5 OUT
2
NC = NO CONNECT. DO NOT
00 3-
CONNECT TO THIS PIN.
88 11 Figure 2. 8-lead MSOP and 8-lead SOIC Pin Configuration
Table 4. 8-lead MSOP and 8-lead SOIC Pin Function Descriptions Pin No. Mnemonic Description
1 −IN Negative Input. 2 GND Ground. 3 VREF2 Reference Input 2. 4 NC No Connect. Do not connect to this pin. 5 OUT Output. 6 VS Supply. 7 VREF1 Reference Input 1. 8 +IN Positive Input.
–IN 1 10 +IN NC 2 9 NC AD8418A GND 3 TOP VIEW 8 VREF1 (Not to Scale) VREF2 4 7 VS NC 5 6 OUT
03 4 3-
NOTES
88
1. NC = NO CONNECT. DO NOT CONNECT TO THIS PIN.
11 Figure 3. 10-lead MSOP Pin Configuration
Table 5. 10-lead MSOP Pin Function Descriptions Pin No. Mnemonic Description
1 −IN Negative Input. 2, 5, 9 NC No Connect. Do not connect to this pin. 3 GND Ground. 4 VREF2 Reference Input 2. 6 OUT Output. 7 VS Supply. 8 VREF1 Reference Input 1. 10 +IN Positive Input. Rev. E | Page 5 of 18 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION OUTPUT OFFSET ADJUSTMENT UNIDIRECTIONAL OPERATION Ground Referenced Output Mode VS Referenced Output Mode BIDIRECTIONAL OPERATION EXTERNAL REFERENCED OUTPUT SPLITTING THE SUPPLY SPLITTING AN EXTERNAL REFERENCE APPLICATIONS INFORMATION MOTOR CONTROL 3-Phase Motor Control H-Bridge Motor Control SOLENOID CONTROL High-Side Current Sense with a Low-Side Switch High-Side Current Sense with a High-Side Switch High Rail Current Sensing PINOUT OPTION ENGINEERED FOR FMEA OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
