Datasheet AD8278, AD8279 (Analog Devices) - 5
ОписаниеLow Power, Wide Supply Range, Low Cost Difference Amplifiers, G = ½, 2
Страниц / Страница24 / 5 — AD8278/AD8279. Table 4. G = ½. Grade B. Grade A. Parameter Conditions. …
ВерсияC
Формат / Размер файлаPDF / 519 Кб
AD8278/AD8279. Table 4. G = ½. Grade B. Grade A. Parameter Conditions. Min Typ. Max Min Typ. Max Unit
AD8278/AD8279 Table 4 G = ½ Grade B Grade A Parameter Conditions Min Typ Max Min Typ Max Unit
Микросхема Буферный усилитель, SP Amp Difference Amplifier Single ±18V/36V 8Pin MSOP T/R
AD8278BRMZ-RL
125 ₽
ЧипСити
AD8278BRMZ-RL
230 ₽
AD8278BRMZ-RL
428 ₽
AD8278BRMZ-RL
link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 16 link to page 11 link to page 12 link to page 12
AD8278/AD8279
VS = +2.7 V to <±5 V, VREF = midsupply, TA = 25°C, RL = 10 kΩ connected to midsupply, G = ½ difference amplifier configuration, unless otherwise noted.
Table 4. G = ½ Grade B Grade A Parameter Conditions Min Typ Max Min Typ Max Unit
INPUT CHARACTERISTICS System Offset1 75 150 75 250 μV Over Temperature TA = −40°C to +85°C 150 250 μV vs. Power Supply VS = ±5 V to ±18 V 2.5 5 μV/V Average Temperature Coefficient TA = −40°C to +85°C 0.3 1 2 5 μV/°C Common-Mode Rejection VS = 2.7 V, VCM = 0 V to Ratio (RTI) 2.4 V, RS = 0 Ω 80 74 dB VS = ±5 V, VCM = −10 V to +7 V, RS = 0 Ω 80 74 dB Input Voltage Range2 −3 (VS + 0.1) +3 (VS − 1.5) −3 (VS + 0.1) +3 (VS − 1.5) V Impedance3 Differential 120 120 kΩ Common Mode 30 30 kΩ DYNAMIC PERFORMANCE Bandwidth 870 870 kHz Slew Rate 1.3 1.3 V/μs Channel Separation f = 1 kHz 130 130 dB Settling Time to 0.01% 2 V step on output, CL = 100 pF, VS = 2.7 V 7 7 μs GAIN Gain Error 0.005 0.02 0.01 0.05 % Gain Drift TA = −40°C to +85°C 1 5 ppm/°C OUTPUT CHARACTERISTICS Output Swing4 RL = 10 kΩ, TA = −40°C to +85°C −VS + 0.1 +VS − 0.15 −VS + 0.1 +VS − 0.15 V Short-Circuit Current Limit ±10 ±10 mA Capacitive Load Drive 200 200 pF NOISE5 Output Voltage Noise f = 0.1 Hz to 10 Hz 1.4 1.4 μV p-p f = 1 kHz 47 50 47 50 nV/√Hz POWER SUPPLY6 AD8278 Supply Current TA = −40°C to +85°C 200 200 μA AD8279 Supply Current TA = −40°C to +85°C 375 375 μA Operating Voltage Range 2.0 36 2.0 36 V TEMPERATURE RANGE Operating Range −40 +125 −40 +125 °C 1 Includes input bias and offset current errors, RTO (referred to output). 2 The input voltage range may also be limited by absolute maximum input voltage or by the output swing. See the Input Voltage Range section for details. 3 Internal resistors are trimmed to be ratio matched and have ±20% absolute accuracy. 4 Output voltage swing varies with supply voltage and temperature. See Figure 22 through Figure 25 for details. 5 Includes amplifier voltage and current noise, as well as noise from internal resistors. 6 Supply current varies with supply voltage and temperature. See Figure 27 and Figur for e 28 details. Rev. C | Page 5 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION SHORT-CIRCUIT CURRENT ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CIRCUIT INFORMATION DC Performance AC Performance DRIVING THE AD8278 AND AD8279 INPUT VOLTAGE RANGE POWER SUPPLIES APPLICATIONS INFORMATION CONFIGURATIONS DIFFERENTIAL OUTPUT INSTRUMENTATION AMPLIFIER OUTLINE DIMENSIONS ORDERING GUIDE
