Datasheet AD8276, AD8277 (Analog Devices) - 3
ОписаниеLow Power, Wide Supply Range, Low Cost Unity-Gain Difference Amplifiers
Страниц / Страница22 / 3 — Data Sheet. AD8276/. AD8277. SPECIFICATIONS. Table 2. Grade B. Grade A. …
ВерсияD
Формат / Размер файлаPDF / 485 Кб
Data Sheet. AD8276/. AD8277. SPECIFICATIONS. Table 2. Grade B. Grade A. Parameter. Test Conditions/Comments Min. Typ. Max. Min. Typ Max. Unit
Data Sheet AD8276/ AD8277 SPECIFICATIONS Table 2 Grade B Grade A Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
36 предложений от 18 поставщиков
AD8276BRZ-RL
184 ₽
Зенер
Россия и страны ТС
AD8276BRZ
от 190 ₽
Эиком
AD8276BRZ
от 490 ₽
AD8276BRZ
link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 9 link to page 9 link to page 9 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10
Supply voltage (VS) = ±5 V to ±15 V, reference voltage (VREF) = 0 V, TA = 25°C, load resistance (RL) = 10 kΩ connected to ground, G = 1 difference amplifier configuration, unless otherwise noted.
Table 2. Grade B Grade A Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
INPUT CHARACTERISTICS System Offset1 100 200 100 500 µV vs. Temperature TA = −40°C to +85°C 200 500 µV Average Temperature TA = −40°C to +85°C 0.5 2 2 5 µV/°C Coefficient vs. Power Supply VS = ±5 V to ±18 V 5 10 µV/V Common-Mode VS = ±15 V, common-mode 86 80 dB Rejection Ratio voltage (VCM) = ±27 V, series Reference to Input (RTI) resistance (RS) = 0 Ω Input Voltage Range2 −2(VS + 0.1) +2(VS − 1.5) −2(VS + 0.1) +2(VS − 1.5) V Impedance3 Differential 80 80 kΩ Common Mode 40 40 kΩ DYNAMIC PERFORMANCE Bandwidth 550 550 kHz Slew Rate 0.9 1.1 0.9 1.1 V/µs Settling Time to 0.01% 10 V step on output, load 15 15 µs capacitance (CL) = 100 pF Settling Time to 0.001% 16 16 µs Channel Separation f = 1 kHz 130 130 dB GAIN Gain Error 0.005 0.02 0.01 0.05 % Gain Drift TA = −40°C to +85°C 1 5 ppm/°C Gain Nonlinearity Output voltage (VOUT) = 5 10 ppm 20 V p-p OUTPUT CHARACTERISTICS Output Voltage Swing4 VS = ±15 V, RL = 10 kΩ, TA = −VS + 0.2 +VS − 0.2 −VS + 0.2 +VS − 0.2 V −40°C to +85°C Short-Circuit ±15 ±15 mA Current Limit Capacitive Load Drive 200 200 pF NOISE5 Output Voltage Noise f = 0.1 Hz to 10 Hz 2 2 μV p-p f = 1 kHz 65 70 65 70 nV/√Hz POWER SUPPLY Supply Current6 200 200 μA vs. Temperature TA = −40°C to +85°C 250 250 μA Operating Voltage ±2 ±18 ±2 ±18 V Range7 TEMPERATURE RANGE Operating Range −40 +125 −40 +125 °C 1 Includes input bias and offset current errors, referred to output (RTO). 2 The input voltage range can also be limited by the absolute maximum input voltage or by the output swing. See the Input Voltage Range section in the Theory of Operation section for details. 3 Internal resistors are trimmed to be ratio matched and have ±20% absolute accuracy. 4 Output voltage swing varies with supply voltage and temperature. See Figure 19 through Figure 22 for details. 5 Includes amplifier voltage and current noise, as well as noise from internal resistors. 6 Supply current varies with supply voltage and temperature. See Figure 23 and Figure 25 for details. 7 Unbalanced dual supplies can be used, such as −VS = −0.5 V and +VS = +2 V. The positive supply rail must be at least 2 V above the negative supply and reference voltage. Rev. D | Page 3 of 22 Document Outline Features Applications General Description Functional Block Diagrams Table of Contents Revision History Specifications Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation Short-Circuit Current ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation Circuit Information DC Performance AC Performance Driving the AD8276/AD8277 Input Voltage Range Power Supplies Applications Information Configurations Differential Output Current Source Voltage and Current Monitoring Instrumentation Amplifier RTD Die Information Die Specifications and Assembly Recommendations Outline Dimensions Ordering Guide
