Datasheet AD8276, AD8277 (Analog Devices) - 4
ОписаниеLow Power, Wide Supply Range, Low Cost Unity-Gain Difference Amplifiers
Страниц / Страница22 / 4 — AD8276. /AD8277. Data Sheet. Table 3. Grade B. Grade A. Parameter. Test …
ВерсияD
Формат / Размер файлаPDF / 485 Кб
AD8276. /AD8277. Data Sheet. Table 3. Grade B. Grade A. Parameter. Test Conditions/Comments Min. Typ. Max. Min. Typ Max. Unit
AD8276 /AD8277 Data Sheet Table 3 Grade B Grade A Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
Микросхема Буферный усилитель, INSTR Amp Single R-R O/P ±18V/36V 8Pin SOIC N T/R
AD8276BRZ-RL
188 ₽
AD8276BRZ-RL
522 ₽
AD8276BRZ-RL
AD8276BRZ-RL
link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 9 link to page 9 link to page 9 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10
VS = +2.7 V to ±5 V, VREF = midsupply, TA = 25°C, RL = 10 kΩ connected to midsupply, G = 1 difference amplifier configuration, unless otherwise noted.
Table 3. Grade B Grade A Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
INPUT CHARACTERISTICS System Offset1 100 200 100 500 µV vs. Temperature TA = −40°C to +85°C 200 500 µV Average Temperature TA = −40°C to +85°C 0.5 2 2 5 µV/°C Coefficient vs. Power Supply VS = ±5 V to ±18 V 5 10 µV/V Common-Mode Rejection VS = 2.7 V, VCM = 0 V to 2.4 V, 86 80 dB Ratio (RTI) RS = 0 Ω VS = ±5 V, VCM = −10 V to +7 V, 86 80 dB RS = 0 Ω Input Voltage Range2 −2(VS + 0.1) +2(VS − 1.5) −2(VS + 0.1) +2(VS − 1.5) V Impedance3 Differential 80 80 kΩ Common Mode 40 40 kΩ DYNAMIC PERFORMANCE Bandwidth 450 450 kHz Slew Rate 1.0 1.0 V/µs Settling Time to 0.01% 8 V step on output, 5 5 µs CL = 100 pF, VS = 10 V Channel Separation f = 1 kHz 130 130 dB GAIN Gain Error 0.005 0.02 0.01 0.05 % Gain Drift TA = −40°C to +85°C 1 5 ppm/°C OUTPUT CHARACTERISTICS Output Swing4 RL = 10 kΩ, −VS + 0.1 +VS − 0.15 −VS + 0.1 +VS − 0.15 V TA = −40°C to +85°C Short-Circuit Current Limit ±10 ±10 mA Capacitive Load Drive 200 200 pF NOISE5 Output Voltage Noise f = 0.1 Hz to 10 Hz 2 2 μV p-p f = 1 kHz 65 65 nV/√Hz POWER SUPPLY Supply Current67 TA = −40°C to +85°C 200 200 μA Operating Voltage Range 2.0 36 2.0 36 V TEMPERATURE RANGE Operating Range −40 +125 −40 +125 °C 1 Includes input bias and offset current errors, RTO. 2 The input voltage range may also be limited by absolute maximum input voltage or by the output swing. See the Input Voltage Range section in the Theory of Operation section for details. 3 Internal resistors are trimmed to be ratio matched and have ±20% absolute accuracy. 4 Output voltage swing varies with supply voltage and temperature. See Figure 19 through Figure 22 for details. 5 Includes amplifier voltage and current noise, as well as noise from internal resistors. 6 Supply current varies with supply voltage and temperature. See Figure 24 and Figure 25 for details. 7 Power dissipation (PDISS) at quiescent condition is computed by multiplying the supply voltage and quiescent supply current (IQ). PDISS = VS × IQ, PDISS = 2.7 V × 200 µA, PDISS = 0.54 mW. Rev. D | Page 4 of 22 Document Outline Features Applications General Description Functional Block Diagrams Table of Contents Revision History Specifications Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation Short-Circuit Current ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation Circuit Information DC Performance AC Performance Driving the AD8276/AD8277 Input Voltage Range Power Supplies Applications Information Configurations Differential Output Current Source Voltage and Current Monitoring Instrumentation Amplifier RTD Die Information Die Specifications and Assembly Recommendations Outline Dimensions Ordering Guide
