Оптопары и оптореле Megawin
Datasheet AD5749 (Analog Devices) - 3
ОписаниеIndustrial Current Out Driver, Single-Supply, 55 V Maximum Supply, Programmable Ranges
Страниц / Страница28 / 3 — Data Sheet. AD5749. SPECIFICATIONS. Table 2. Parameter1 Min. Typ. Max. …
ВерсияE
Формат / Размер файлаPDF / 399 Кб
Data Sheet. AD5749. SPECIFICATIONS. Table 2. Parameter1 Min. Typ. Max. Unit. Test. Conditions/Comments
Data Sheet AD5749 SPECIFICATIONS Table 2 Parameter1 Min Typ Max Unit Test Conditions/Comments
32 предложений от 14 поставщиков
AD5749ACPZ-RL7
169 ₽
AD5749ACPZ-RL7
212 ₽
Эиком
AD5749ACPZ-RL7
от 621 ₽
AD5749ACPZ-RL7
от 793 ₽
link to page 22 link to page 22 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
AVDD = 12 V (± 10%) to 55 V (maximum), DVCC = 2.7 V to 5.5 V, GND = 0 V. RLOAD = 300 Ω. All specifications TMIN to TMAX, unless otherwise noted.
Table 2. Parameter1 Min Typ Max Unit Test Conditions/Comments
INPUT VOLTAGE RANGE 0 to 4.096 V Output unloaded Input Leakage Current −1 +1 μA REFERENCE INPUT Reference Input Voltage 4.096 V External reference must be exactly as stated; otherwise, accuracy errors show up as error in output Input Leakage Current −1 +1 μA CURRENT OUTPUT Output Current Ranges 0 24 mA 4 20 mA Output Current Overranges2 0 24.5 mA See Detailed Description of Features section 3.92 20.4 mA See Detailed Description of Features section ACCURACY (INTERNAL RSET) Total Unadjusted Error (TUE) A Version2 −0.5 +0.5 % FSR −0.3 ±0.15 +0.3 % FSR TA = 25°C Relative Accuracy (INL) −0.02 ±0.01 +0.02 % FSR Offset Error −16 +16 μA −10 +5 +10 μA TA = 25°C Offset Error TC2 ±3 ppm FSR/°C Dead Band on Output, RTI 8 14 mV Referred to 4.096 V input range Gain Error −0.2 +0.2 % FSR −0.125 ±0.02 +0.125 % FSR TA = 25°C Gain TC2 ±10 ppm FSR/°C Full-Scale Error −0.2 +0.2 % FSR −0.125 ±0.02 +0.125 % FSR TA = 25°C Full-Scale TC2 ±4 ppm FSR/°C ACCURACY (EXTERNAL RSET) Total Unadjusted Error (TUE) A Version2 −0.3 +0.3 % FSR −0.1 ±0.02 +0.1 % FSR TA = 25°C Relative Accuracy (INL) −0.02 ±0.01 +0.02 % FSR Offset Error −14 +14 μA −11 +5 +11 TA = 25°C Offset Error TC2 ±2 ppm FSR/°C Dead Band on Output, RTI 8 +14 mV Referred to 4.096 V input range Gain Error −0.08 +0.08 % FSR −0.07 ±0.02 +0.07 % FSR TA = 25°C Gain TC2 ±1 ppm FSR/°C Full-Scale Error −0.1 +0.1 % FSR −0.07 ±0.02 +0.07 % FSR TA = 25°C Full-Scale TC2 ±2 ppm FSR/°C Rev. E | Page 3 of 28 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY TIMING CHARACTERISTICS Timing Diagrams ESD CAUTION SOFTWARE MODE CURRENT OUTPUT ARCHITECTURE DRIVING INDUCTIVE LOADS POWER-ON STATE OF THE AD5749 DEFAULT REGISTERS AT POWER-ON RESET FUNCTION OUTEN SOFTWARE CONTROL Input Shift Register Status Bit Read Operation HARDWARE CONTROL TRANSFER FUNCTION OUTPUT FAULT ALERT—SOFTWARE MODE OUTPUT FAULT ALERT—HARDWARE MODE ASYNCHRONOUS CLEAR (CLEAR) EXTERNAL CURRENT SETTING RESISTOR PROGRAMMABLE OVERRANGE MODES PACKET ERROR CHECKING TRANSIENT VOLTAGE PROTECTION THERMAL CONSIDERATIONS LAYOUT GUIDELINES GALVANICALLY ISOLATED INTERFACE MICROPROCESSOR INTERFACING ORDERING GUIDE
